CPU CPU CPU
Go to solution Solved by Crunchy Dragon,
Just now, hconverse02 said:
Definitely needs a 1050 ti.
Then do it, by all means
Depends on use case, does he need all the power of a 1050Ti or will he be fine on integrated Vega?
-Moved to New Builds and Planning-
https://linustechtips.com/topic/898227-cpu-cpu-cpu/#findComment-11063116
Really depends on the budget.  Unfortunately the 1050ti prices have also gone up, at least they have in my country.  Since the build is for a friend I'd suggest you show him some videos of what the ryzen APU is capable of to set his expectations.  Then price out two builds and let him decide.
https://linustechtips.com/topic/898227-cpu-cpu-cpu/#findComment-11063120
Definitely needs a 1050 ti. EDIT: but he needs something to go off of for now, so I thought it would be better than a mobile 970 2gb from his other system.
https://linustechtips.com/topic/898227-cpu-cpu-cpu/#findComment-11063136
This ^^^ And from what I've seen, the APUs should be fine for 1080p low in AAA games (at least), and do fine in lighter games like Overwatch and such.
Gaming PC NAS Laptop Workstation
CPU: i5 12600KF 6P+4E Ryzen 7 3700X M4 SoC 4P+6E Xeon X5690 6c12t
Cooler: Noctua NH-D15S Wraith Stealth w/NF-A9 Passive Apple CPU Cooler
Motherboard: ASRock Z690 ITX/ax ASUS Pro B550M-C/CSM Apple J713AP Mac-F221BEC8 (Mac Pro 5,1)
RAM: 2x16GB 3600Mhz DDR4 2x16GB 2400MHz DDR4 24GB Micron LPDDR5 4x8GB 1333MHz ECC DDR3
GPU: Sapphire Pulse Radeon 9060 XT 16GB Radeon WX2100 M4 SoC 10C Radeon RX 5700
Storage: 1TB MP34 + 2TB P41 500GB SSD + 2x4TB IronWolf Pro in ZFS Mirror Apple AP0512Z 1TB Crucial MX500
ODD: LG WH14NS40 None LG GP65NB60 USB DVD Writer Don't know
PSU: EVGA 850W GM Silverstone SST-TX300 53.8Wh LiPo Battery Delta DPS-980BB
Case: Silverstone Sugo 14 Dell Inspiron 530S Mac16,12 chassis (13" MBA) 2009-2012 Mac Pro "Cheese Grater"
OS: Gentoo Linux TrueNAS Scale macOS 26 Tahoe Fedora Linux
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 14" M5P MacBook Pro (work) - iPhone 17 Pro - Apple Watch S11
Other Misc Devices: iPod Video (Gen 5.5E, iFlash Solo w/128GB SD Card, Rockbox), Nintendo Switch
Vehicles: 2002 Ford F150, 2003 Harley-Davidson Sportster 1200, 2022 Kawasaki KLR650, 1994 DR350SE
https://linustechtips.com/topic/898227-cpu-cpu-cpu/#findComment-11063142
https://linustechtips.com/topic/898227-cpu-cpu-cpu/#findComment-11063144
