How to remove plastic side panel scratch?
By
Age of 9394
in Power Supplies
in Power Supplies
Solved by W-L,
35 minutes ago, Age of 9394 said:How to remove plastic side panel scratch?
Will NOVUS Plastic Polish work?
Novus does a good job at removing scratches, but similar with any plastic panel they will come back from cleaning the panel.
l3eyond ·
1
Serendipity1344 ·
Posted in Graphics Cards4 -
1
1
5
1
toxic_worper ·
Posted in New Builds and Planning9
