Hey Guys,
I just finished putting together my new PC, I ended up replacing my aging i5 2320 system with a RYZEN 1600.
I opted for the 1600 because it was cheaper and I could always upgrade to a 1700x or 1800x  later if needed.
Also due to the high cost of GPU i'm reusing my GTX 980, it still works so no big deal there.
Also used Grizzly Liquid Metal on the CPU, later I will be re-pasting the GPU and the chipset heatsync (it gets to 60 Degrees (Celsius), and i want to see if i can drop the temps due to in being almost 40 degrees hotter then any other temperature on the PC)
Overall I love this case and the AIO is spectacular, never exceeds 60 Degrees (Celsius) under full load with AIDA64 and fans on silent.
Also sorry about the pictures, My Note 8 takes either decent pictures or absolutely terrible pictures, and the 20MB upload restriction is a pain, i am going to be adding more to this thread, did allot of recording to still go thru....My roommate is captain shaky CAM.
Motherboard----ASUS X370 Prime PRO
CPU---------------RYZEN 1600 Overclocked to 4Ghz
RAM---------------Crucial Ballistics 8GB DDR4 Overclocked to 3000Mhz----(I also have a 4GB Patriot DDR4 stick, but I'm not a big fan of mixing RAM)
GPU---------------GTX 980 Reference
Case--------------CoolerMaster MasterBox 5
CPUCooler------CoolerMaster Master Liquid ML240L RGB
SDD---------------SanDisk 128GB SSD---(I have a 960EVO but ended up using it in my laptop instead)
HDD---------------SeaGate 4TB ST4000LM016
PSU---------------Antec 750W
https://linustechtips.com/topic/897944-ryzen-1600-build-argo/
Completely finished, RAM installed BIOS Updated and overclocks set. Also bought a LED strip and installed in inside the case...Need to figure out the wiring a little more, wish it was a little cleaner, but its not bad.
Ill get my stress tests and benchmarks posted asap.....
https://linustechtips.com/topic/897944-ryzen-1600-build-argo/#findComment-11060793
