So I bought two 1080ti's and for some reason im having issues. I used the game the witcher 3 and im only getting single card performance yet the top card says 80% and the bottom sits at 60-70%. This has me so annoyed if I cant find a fix Im selling the secon card. I tried both cards without sli and they both work as intended so, an I tried swapping the top and bottom card so im at a 100% loss here.
CPU: 6700K Case: Corsair Air 740 CPU Cooler: H110i GTX Storage: 2x250gb SSD 960gb SSD PSU: Corsair 1200watt GPU: EVGA 1080ti FTW3 RAM: 16gb DDR4
Other Stuffs: Red sleeved cables, White LED lighting 2 noctua fans on cpu cooler and Be Quiet PWM fans on case.
https://linustechtips.com/topic/897687-sli-issues-need-help/
most games are not sli ready, some actually perform worse with sli, its better to stick with one
https://linustechtips.com/topic/897687-sli-issues-need-help/#findComment-11057482
Witcher 3 is well known for having good sli support.
https://linustechtips.com/topic/897687-sli-issues-need-help/#findComment-11057484
If they are both working it’s supported.
Sounds like an issue elsewhere.
Need specs and stats of hardware while under load.
https://linustechtips.com/topic/897687-sli-issues-need-help/#findComment-11058084
  • 2 weeks later...
U found out the issue. It doesn't like my ultrawide. Runs fine with both at 100% on the 16:9 monitor but for some reason I think it's seeing my ultrawide as multi monitor and not a single screen.
https://linustechtips.com/topic/897687-sli-issues-need-help/#findComment-11099880
Surprised that cpu is keeping up regardless. That's the only issue I had, sli with enough pixels was stressing the cpu too much and dropping performance for the cards.
https://linustechtips.com/topic/897687-sli-issues-need-help/#findComment-11099899
I was getting over 200fps in 1080p when I tested my CPU. Only saw 50% CPU utilization when I did that in Witcher 3. When I put it in 4k it's not a issue at all as the fps doesn't get high enough to overload the CPU with frames to render.
Edit: i7 6700k is more then enough CPU power for what I'm using these cards for. Seems to just be a issue with the ultrawide and sli.
https://linustechtips.com/topic/897687-sli-issues-need-help/#findComment-11099912
Shouldn't change anything unless the game has an issue at that res. I play at 3k for a lot of games and only had issues with cpu's for a few. I tend to play cpu intensive games though so it happens often.
https://linustechtips.com/topic/897687-sli-issues-need-help/#findComment-11099951
Do you have AA enabled?
If so, disable it and use ReShade FXAA or Driver FXAA. Witcher 3 uses TAA, which kills SLI at higher resolutions.
Gaming Rig
CPU: Intel i7-6850k @ 4.2GHz
GPU: 2x FE GTX 1080Ti
Memory: 16GB PNY Anarchy DDR4 3200MHz
Motherboard: ASRock X99 Extreme 4
Encoding Rig
CPU: Ryzen 7 1700 @ 3.7GHz
GPU: GTX 1050
Memory: 8GB Curcial Ballistix DDR4 2133MHz
Motherboard: Gigabyte AB350M-DS3H
https://linustechtips.com/topic/897687-sli-issues-need-help/#findComment-11100241
