Hello I have yet another dumb question about water-cooling.
so i want to watercool with hardline.
I have a gpu waterblock, cpu waterblock, 2 120mm radiators, a pump with 2 ports, a resivoir with a in and out and a drain valve.
The case is a corsair air 240
I realy just want to know a good cheap fitings option or a build.
An ek configurater costs $150 for the fittings hope theres a cheap option and i need 14 fittings overall.
hope yall can help
https://linustechtips.com/topic/897648-help-water-cooling/
hope yall can help
As said before watercooling is not cheap, but for fittings there are lots of options out there, EKWB's are fairly affordable other options such as Barrow are pretty good, as said before there isn't any guarantee if something were to go wrong.
https://linustechtips.com/topic/897648-help-water-cooling/#findComment-11056868
