Are you plugging your headphones all the way into the headphone jack? In the past I've experienced something similar to what you're describing and it turned out I hadn't plugged it in all the way.
-Moved to Troubleshooting-
yes still not working
2 hours ago, m2234323 said:
what do you mean i only heard it in one ear  and not my ear work in other pc and flip them around on side i can barely here
If you're interested in a product please download and read the manual first.
Don't forget to tag or quote in your reply if you want me to know you've answered or have another question.
7 minutes ago, m2234323 said:
that is in the middle for me  do not really solve the issue just temp fix i think the mother board is mess up
May be the port is damaged. If you do have realtek then the good thing is you can assign a different jack. I suggest try that.
edit.. ah nm. just remembered front panel also not working
yep   just test it just made one side loder or s quiter
Uninstall current driver and install latest driver from realtek website.
Maybe windows update screwed your installations. Happened to me once.
