Hello,
I'm thinking of upgrading my audio setup. I was thinking of getting the Beyerdynamic Dt990Pro combined with the Modi2+Magni3. Would it be a huge improvement from my current setup(onboard sound from the MSI Z270 M5 and the Sennheiser PC360 special edition)? Are there better options? Is it worth it? Or should I stick with the headset and just get a Dac? Btw. I'm using it only for gaming and listening to music.
I was thinking of getting a separate mic like the Blue Snowball.
I appreciate any suggestions because I most likely don't have the necessary knowledge of this topic.
Greetings
https://linustechtips.com/topic/896884-audio-setup/
3 hours ago, t.bender94 said:
In terms of sound quality.
So you suggest no Dac/amp?
Some headphones scale well with better audio gear, like good DAC stack/combo, an example of such a headphone is the HD600/HD650/HD6XX, but with most lower end cans, the difference can be subtle (really depends on your hearing). If you can get the DT990 loud enough with your mobo audio and you're satisfied with the sound, stick with the mobo. Buy a DAC stack/combo only IF you intend to upgrade your headphones to higher end ones.....
 Main Rig: AMD AM4 R7 5700X3D (8C/16T) + TR Phantom Spirit 120 EVO | Gigabyte X570 Aorus Xtreme | 2x 16GB Kingston Fury Beast DDR4 3600 | XFX MERC 310 RX 7900 XTX | 256GB Sabrent Rocket NVMe M.2 PCIe Gen 3.0 (OS) | 4TB Crucial P310 NVMe M.2 PCIe4x4 | 2TB TG Cardea Zero Z440 NVMe M.2 PCIe Gen4x4 | 4TB Samsung 860 EVO SATA SSD | 2TB Samsung 860 QVO SATA SSD | 6TB WD Black HDD | CoolerMaster H500M | Corsair HX1000 Platinum | Logitech G915 + G303 Shroud Ed + 8BitDo Ultimate 2.4G | iFi Micro iDSD Black Label | Philips Fidelio B97 | C49HG90DME 49" 32:9 144Hz Freesync 2 | Omnidesk Pro 2020 48" | 64bit Win11 Pro 24H2
2nd Rig: AMD AM4 R9 5900X (12C/24T) + TR PA 120 SE | Gigabyte X570S Aorus Elite AX | 2x 16GB Patriot Viper Elite II DDR4 4000MHz | Sapphire Nitro+ RX 6900 XT | 500GB Crucial P2 Plus NVMe M.2 PCIe Gen 4.0 (OS) | 2TB Adata Legend 850 NVMe M.2 PCIe Gen4x4 |  2TB Kingston NV2 NVMe M.2 PCIe Gen4x4 | 4TB Leven JS600 SATA SSD | 2TB Seagate HDD | Logitech G613 + G703 | SOLDAM XR-1 Black Knight | Enermax MAXREVO 1500 | 64bit Win11 Pro 24H2
HTPC: AMD R7 6800H | 32GB DDR5 4800MHz | AMD 680M iGPU | 2TB SSD (2 Partitions 400GB + 1.4TB)) + 1TB SSD | Logitech G613 + G304 | Win11 Pro  24H2
Laptop: Lenovo Legion 5 Pro 16ACH6H - AMD 5800H | 32GB DDR4 3200MHz | 680M iGPU | 1TB Kingston NV1 NVMe M.2 (OS) | 4TB Lexar NM790 SSD | Win11 Pro
https://linustechtips.com/topic/896884-audio-setup/#findComment-11050184
