Recently I've noticed, with my headphones on, I can hear the system working..
always when I perform some heavier action (opening software, importing images in Lightroom etc) I hear a short scratching sound.
no idea how this is possible.. is it the SSD, RAM, CPU or GPU ?
Any engineers here that can clarify this ?
https://linustechtips.com/topic/896723-hearing-the-system-work/
From the above mentioned only the GPU might be a reason.
Other reasons:
- PSU
- HDD if you have one
CPU: Ryzen 7 2700x, Cooling: Corsair H100i Platinum AIO MOBO: Asus Strix B450 F GPU: Gigabyte GTX 1080 Founders Edition + Arctic Accelero Xtreme III RAM: 2x8GB ThermalTake ToughRAM White 3200MHz PSU: Corsair RM850x White Storage: 250GB Samsung 970 Evo NVMe CASE: Corsair 275r Airflow White OTHER: White and Orange Cable Extensions ---- MONITOR: Samsung LC32JG5 32" WQHD 1440p VA 144Hz
https://linustechtips.com/topic/896723-hearing-the-system-work/#findComment-11047540
From where is the sound coming? Try listening a bit and check from where it comes. There are various sounds that may come from the PSU, GPU(fans sometimes), CPU(also fan) or even the hard disk(if you've got one).
 || CPU: Intel i5-8600K || Cooler: CoolerMaster Hyper 212X || Motherboard: Gigabyte Z370 HD3P || GPU: Gigabyte GTX 1050ti OC Windforce 4GB || Memory: 16GB Crucial DDR4 3000mhz || HDD: WD Black 500GB + Seagate Barracuda 2TB || SSD: Samsung 980 1TB || PSU: Corsair VS550 || Case: nJoy Ice Cage || Fans: Segotep Halo Ring RGB ||Monitor: 2x Dell 27" P2717H IPS Full HD || Second Monitor/TV: LG 49UJ620V UHD || Mouse: Logitech G502 || Keyboard: Logitech G810 + Royal Kludge RK84 || Speakers: Philips SPA-5300 subw + Arylic 2.1 + DIY Bookshelves w/ Dayton Audio || Headphones: HyperX Cloud Flight S ||
TO BE UPGRADED:
>> Headphones << >> Keyboard << >> HDD << >> Mouse << >> PC Case << >> Memory(another stick) << >> Graphics Card <<
https://linustechtips.com/topic/896723-hearing-the-system-work/#findComment-11047542
This might just be that the audio components on your motherboard is picking up electrical interference from the rest of the components, it depends on your board as a lot of the recent more gaming/expensive ones have a shielded part of the board dedicated to audio parts. This is also why shielded dedicated audio cards used to be a thing in the past.
https://linustechtips.com/topic/896723-hearing-the-system-work/#findComment-11047610
20 minutes ago, NinJake said:
When I hear scratching all I think of is hard drives and DJs.
Guitars can scratch too (=
Like @Sack said, it could be the audio components getting electrical interference.
https://linustechtips.com/topic/896723-hearing-the-system-work/#findComment-11047646
