Hey guys, sorry if I'm digging up old topics but I'm fairly new to computer upgrades and builds. I built a gaming computer in 2010, but I am wondering what to do with my current build. I just bought a new corsair 650w rmi psu, an evga 128gb ssd and a new blue?WD 1tb hdd for upgrades so far.. BTW I have never OC'D any of it. My budget is not the greatest right now to do a complete upgrade to intel or new Ryzen. Also, a new gpu is out of the question due to really bad gpu prices right now. I've watched a ton of Linus's  vids but just not finding the info I need. Can I put an fx 8350 or 8370 in this?  Please heeeeelp!
My build-----------
Coolermaster mid atx case
msi 890fxa gd70 mobo
amd phenom 2 x6 1055t cpu
xfx ati Radeon 5770 1gb gpu
coolermaster v8 CPU cooler
2-120mm case fans
8gb gskill ddr3 2133 MHz ram- got it on the cheap
500gb WD caviar hdd
corsair 450w psu
https://linustechtips.com/topic/896318-need-serious-advise-please/
Upgrade the graphics card, then the CPU once you have enough money.
Computer engineering PhD student and RFML researcher
Daily Driver:
CPU: Ryzen 7 4800H | GPU: RTX 2060 | RAM: 32GB DDR4 3200MHz C16 | OS: Debian 13
Gaming PC:
CPU: Ryzen 5 5600X | GPU: EVGA RTX 2080Ti | RAM: 32GB DDR4 3200MHz C16 | OS: Windows 11
Just now, Codeman36 said:
What would be a good graphics card for this set up? Without getting bottlenecked too bad?
A GTX 970 max, you will still get bottlenecks, but it's sensless to buy low end stuff. You might also want to look into some R9 200 series GPUs
Your motherboard, the msi 890fxa gd70, is using socket AM3+. So you could slap a 8350 or 8370 in it.
But at first you should really upgrade the GPU. Second hand 970's are around 200 euros. But you could also look for a 1050ti.
PC Specs: Intel Core i7-8700k - Asus ROG Z370 MAXIMUS X HERO - 2x8gb Kingston Predator DDR4 3200MHz - MSI GeForce GTX 1080 Ti gaming X Be Quiet! Dark Rock Pro 4 - Samsung 850 PRO 256gb - Samsung 850 EVO 500gb - Seagate Barracuda 2tb - Fractal Design Meshify C - Asus PCE-AC56 - Be Quiet! Straight Power 10 CM 700W.
Peripherals: Corsair K70 LUX - Steelseries Rival 310 - Dell S2417DG - Beyerdynamic Custom One Pro - Audioengine D1.
Personally, I'd stick with the Phenom and look for a GPU. The FX series weren't really a big upgrade from the Phenom's and that 1055t should do just fine with a lower-mid range GPU. You could look for a used R9 280/290 or GTX 970. Something like a HD 7870 shouldn't be too expensive and would act as a good stop gap until GPU prices go down a bit. You could even look for something like a 780Ti. Prices shouldn't be too bad for them.
Gaming PC: i5 8600k @ 4.8GHz | 16GB T-Force Delta RGB @ 3200Mhz | Asus Prime Z370-A | Sapphire Radeon VII (Dead :( ), RX480 8GB | EVGA SuperNova 750 G2 | 120GB Sandisk SSD Plus, 120GB Kingston A400 | 4TB Seagate 7200RPM , 1TB WD Blue 7200RPM | Phanteks P400 Windows 10, MacOS Catalina
Second PC: i5 3340s @ 2.8GHz | 8GB Corsair Vengeance @ 1333MHz | EVGA 750Ti SC | Cheap £7 250GB WD HDD Windows 7
LaptopLate 2009 MacBook (Core 2 Duo, 4GB Ram, 120GB SSD, 9400m, running Mojave) , Late 2013 MacBook Pro Retina (i5, 4GB Ram, 128GB SSD)
Consoles: Xbox One, PS4 Slim, PS3 slim, Xbox 360 fat still going strong after almost 10 years, Original Xbox, PS2, PS1
Phone: Realme 6, Xiaomi Mi A2, Xiaomi Redmi Note 4x, iPhone 6s (jailbroken)
Tablet: iPad Mini 2nd Gen Retina (Jailbroken)
Headphones:  Hifiman HE4xx, Phillips Fidelio X2, Status Audio CB-1,  Fiio E10k DAC, Schiit Magni 3+, Tin T2 IEM's, Astrotec S80
Keyboards:  2x Custom 60% - 1x Gateron Yellow, 1x Box Reds
the FX chips have lower ICP than the Phenom you have in there right now, no reason to upgrade really so just OC it if the motherboard has an OK VRM and swap the GPU for something newer
Builds:
15 minutes ago, Codeman36 said:
I've found asus rog strix 1050ti 4gb for around 250 Canadian dollars through newegg. Seems like a legit card. Reviews seem alright, also found a fx 8370 for 174 canadian dollars as well. Would a new CPU make that much difference?
skip the 8370, not worth the price.
