So today, most of the items I've ordered came in early this week, And when I was trying to fit my new cryorig h7 cooler into my Gigabyte GA-990FXA-UD3 MoBo, it doesn't seem to want to fit. I wonder if anyone else with the same motherboard was able to fit a cryorig h7? Also, I'd appreciate if anyone can give me any recommendations for a good CPU cooler for the motherboard I currently have, my current budget is $40.
Current Build
CPU: i5-8600k (Stock Clocks)
CPU Cooler: Cryorig - H7
Motherboard: MSI - Z370-A Pro
RAM: Patriot - 16GB (2x8GB) DDR4 3400
HDD: Seagate - 1TB BarraCuda
SSD: Samsung - 850 Evo (500 GB) & Samsung - 850 Evo (1TB)
Video Card: EVGA - GTX 970 SSC
Case: Corsair - 760t
Power Supply: Seasonic - G-Series 650 watt
Monitor: Dell -  S2417DG 23.8" G-Sync 2560x1440 165Hz
Keyboard: Corsair - K70 Rapidfire
 Cherry MX speeds
Mouse: Logitech - G502
Headphones: HyperX - Cloud II 7.1 Surround Sound
https://linustechtips.com/topic/896249-cryorig-h7-fitting-problems/
sorry, it took long I had to reassemble it as I was really pissed off not being able to fit it in. but the problem is that the two crossbars aren't wide enough to go into the screws, I followed the instructions given to me by the manual, and I even watched youtube videos to try and figure out what i did wrong
Current Build
 Cherry MX speeds
the pictures are tilted as I used my phone to take a picture
Current Build
 Cherry MX speeds
thanks, I'll try that out tomorrow once I'm out of work.
Current Build
 Cherry MX speeds
yes, I'm using the mounts that they've given me, as I don't have any other mounts since I've been using the stock cooler for a long time.
Current Build
 Cherry MX speeds
yep, I used everything given to me from the package.
Current Build
 Cherry MX speeds
I really don't know why it isn't fitting, to be honest. I bought the cryorig h7 because supposedly PcPartPicker said it was 'compatible.' also I wasn't able to find a topic on the use of cryorig h7 on my MoBo, so I went on and bought it. But I should have picked the cooler master hyper 212 Evo since everyone with the same MoBo as me was using that.
Current Build
 Cherry MX speeds
You have the bracket on the cooler wrong. The "arms " should be hugging the heatpipes.
Black Knight-
Ryzen 5 5600, GIGABYTE B550M DS3H, 16Gb Corsair Vengeance LPX 3000mhz, Asrock RX 6800 XT Phantom Gaming,
Seasonic Focus GM 750, Samsung EVO 860 EVO SSD M.2, Intel 660p Series M.2 2280 1TB PCIe NVMe, Linux Mint 20.2 Cinnamon
Daughter's Rig;
MSI B450 A Pro, Ryzen 5 3600x, 16GB Corsair Vengeance LPX 3000mhz, Silicon Power A55 512GB SSD, Gigabyte RX 5700 Gaming OC, Corsair CX430
Like this.
Black Knight-
Daughter's Rig;
19 hours ago, asand1 said:
Like this.
yea, another forum has helped me already so I fixed it right away. But thanks for the help!
Current Build
 Cherry MX speeds
