Carbide 500r help!!
Go to solution Solved by WoodenMarker,
It fits just fine.
I am considering purchasing an ASUS GTX 780 direct cu II gpu and I am wondering if it will fit in my Corsair Carbide 500r case. Can someone answer this please?
i7 4770k 3.5ghz ~ Corsair h100i ~ ASUS Maximus IV HERO ~ EVGA GTX 780ti ACX SC ~ Corair Vengence 8gb RAM ~ Samsung 840 120gb SSD ~ WD Black 1tb HDD 7200 ~ Corsair HX850 PSU ~ Corsair Carbide 500r ~ Razer Black Widow Ultimate ~   Razer Deathadder 3.5 ~ Triton AX PRO ~ BenQ 27" & acer 23"
https://linustechtips.com/topic/89601-carbide-500r-help/
It fits just fine.
https://linustechtips.com/topic/89601-carbide-500r-help/#findComment-1211142
It fits just fine.
Thanks much man!!!
https://linustechtips.com/topic/89601-carbide-500r-help/#findComment-1211151
It fits just fine.
one more quick question...i have a 4770k and h100i too so will my corsair 850 watt psu work fine?
https://linustechtips.com/topic/89601-carbide-500r-help/#findComment-1211247
It's more than enough. A good 550w would already be plenty.
I'd recommend planning the build as a whole and not part by part unless you're asking for an unbalanced system.
https://linustechtips.com/topic/89601-carbide-500r-help/#findComment-1211253
I actually just swapped out my amd mobo and cpu for intel
https://linustechtips.com/topic/89601-carbide-500r-help/#findComment-1211273
