Looking for a good pre built for my brother in law, budget is 1-1k but he wants to preferably keep it at the 800 range and not spend 1k. I'm thinking a quad core cpu, nothing too expensive because hes only gonna game on it, no content creation, just gaming. Probably at least a 1050 ti, he probably won't play anything too demanding on it and can upgrade later if he wants too.
What I've found so far.
https://www.newegg.com/Product/Product.aspx?item=N82E16883102097 add a 100$ 1080p60hz monitor and there's 1k.
https://www.newegg.com/Product/Product.aspx?Item=9SIABFS6DU7577
https://www.newegg.com/Product/Product.aspx?Item=9SIAA0S6Y72168 best ive found so far, add a 100$ monitor and cheapo keyboard and mouse combo.
Jesus is the way, the truth, and the life.
Please Quote me when replying.
CPU
 - Ryzen 7 5800X3D | RAM - 32GB DDR4 4000Mhz | MB - MSI B550 A-PRO | Boot - 2TB NVME 980 Evo Plus | GPU - EVGA FTW3 RTX 3090 24GB
https://linustechtips.com/topic/895541-help-finding-a-good-pre-built/
you can get 1060 desktops at this price
this is closer to the lower range
https://www.amazon.com/HP-Pavilion-Processor-Graphics-Bluetooth/dp/B077RX4RKD/ref=sr_1_3?ie=UTF8&qid=1518394262&sr=8-3&keywords=1060+desktop
this is closer to the higher range
https://www.amazon.com/CYBERPOWERPC-GUA4500A-FX-6300-GTX1060-Desktop/dp/B01ICLADUA/ref=sr_1_10?ie=UTF8&qid=1518394216&sr=8-10&keywords=1060+desktop
i think both are good for the price considering they're pre-built
i can also give some good monitor recommendations if you want
Lower one doesn't have an SSD, could one be added? I built my PC so I know how to do it, just not sure if the PC can be upgrade or w/e.
The higher one, eww... an fx 6300? Are they even viable anymore lol?
CPU
its literally a 3.5ghz 6 core, its not "eww"
getting a pre-built when you know how to build a PC is "eww"
Too expensive to build right now.
Eww.
CPU
