CSGO fps issues
Go to solution Solved by EnergyEclipse,
1 minute ago, Eternal Lag said:
Hey guys I have a quick question, I've been trying to play CS:GO with my AMD A4 5300B APU and my GT 1030 GPU. For some reason my fps is only like 25 to 35 fps is really irritating. My gpu driver is up to date. What should I do?
Does your Operating System have an update? Or maybe you have some applications running in the background and you might not have noticed.
Otherwise for lower end system I think it might just be a case of Anti-Aliasing, maybe try lowering the AA and see if there is any results :D
I once did the unthinkable, back many headphones ago...
I split an audio split, again
https://linustechtips.com/topic/895464-csgo-fps-issues/#findComment-11033871
I have this weird thing in my taskmanager that says "system interrupts" and it looks like it takes up 5% of my cpu usage...
https://linustechtips.com/topic/895464-csgo-fps-issues/#findComment-11033897
Just now, Konrad Kwasniewski said:
Well, this is a weak computer, the A4 is definitly a major bottleneck. Lower your resolution to 720p, and set AA to off.
What fps do you think I should be getting? I thought I would Easily get at least 30s... I've already lowered the settings down the lowest I could and I've even downloaded fps configs and yet still bad performance.
https://linustechtips.com/topic/895464-csgo-fps-issues/#findComment-11033935
Well, I think a system like that should get 40-50 at 720p low.
https://linustechtips.com/topic/895464-csgo-fps-issues/#findComment-11033939
1 minute ago, Konrad Kwasniewski said:
Well, you are hitting the cpu bottleneck really hard.
yeah, is there away to like max out the GPU demanding settings to make the game run mostly on my GPU rather than my CPU? Or is that not possible with my setup?
https://linustechtips.com/topic/895464-csgo-fps-issues/#findComment-11033960
Unfortunately this system is going struggle in gaming due to main components (i.e. CPU and GPU) being too slow to handle loads like that.
زندگی از چراغ
Intel Core i7 7800X 6C/12T (4.5GHz), Corsair H150i Pro RGB (360mm), Asus Prime X299-A, Corsair Vengeance LPX 32GB (4X4GB & 2X8GB 3000MHz DDR4), MSI GeForce GTX 1070 Gaming X 8G (2.113GHz core & 9.104GHz memory), 1 Samsung 970 Evo Plus 1TB NVMe M.2, 1 Samsung 850 Pro 256GB SSD, 1 Samsung 850 Evo 500GB SSD, 1 WD Red 1TB mechanical drive, Corsair RM750X 80+ Gold fully modular PSU, Corsair Obsidian 750D full tower case, Corsair Glaive RGB mouse, Corsair K70 RGB MK.2 (Cherry MX Red) keyboard, Asus VN247HA (1920x1080 60Hz 16:9), Audio Technica ATH-M20x headphones & Windows 10 Home 64 bit.
The time Linus replied to me on one of my threads:
https://linustechtips.com/topic/895464-csgo-fps-issues/#findComment-11033983
