S7 Edge Screen Damage Question.
Solved by RollinLower,
2 minutes ago, five potatoes said:
I have a screen replacement kit, so I have all of the tools, i just don't know if I have to replace the digitizer.
that would depend on the kit you bought.
still tough, if you got one of those kits with the plastic prying tools and a piece of glass you need some luck ![]()
