7700hq Normal Load temp?
Go to solution Solved by Squanchy,
To whom finds this post, I replaced the thermal compound which did lower it by about 3 degrees overall. But what really did it was undervolting the cpu using XTU by -.15v on the core. No performance loss or crashing.. That itself dropped the temperature by -10c.
Good luck to whom finds this.
Hey all,
I have a GL502vs with a 1070 and a 7700hq... Mainly playing overwatch, decided to check out the temps.. GPU is at about 85c which from what I've seen is pretty normal for a laptop. But the 7700hq is right around 95c, peaked up to 98c... this is with fans at max.. Is this actually normal? I honestly don't think so... but anyone else have some insight?
https://linustechtips.com/topic/894547-7700hq-normal-load-temp/
That's pretty high, even for a laptop CPU in my opinion. Have you replaced the thermal compound?
https://linustechtips.com/topic/894547-7700hq-normal-load-temp/#findComment-11025819
I have not, Was going to order some up... I've always used arctic silver 5.. is there something better then that nowadays?
https://linustechtips.com/topic/894547-7700hq-normal-load-temp/#findComment-11025823
https://linustechtips.com/topic/894547-7700hq-normal-load-temp/#findComment-11026074
XTU is awesome. I recommend anyone who buys a laptop with an Intel CPU to do exactly this.
I got a 0.175v undervolt on my MSI GS63VR with an i7-6700HQ, and that thing went from thermal throttling in Destiny 2 (the most demanding game I own) to sitting around 70C.
Current Build:
CPU: Ryzen 7 5800X3D
GPU: RTX 3080 Ti FE
RAM: 32GB G.Skill Trident Z CL16 3200 MHz
Mobo: Asus Tuf X570 Plus Wifi
CPU Cooler: NZXT Kraken X53
PSU: EVGA G6 Supernova 850
Case: NZXT S340 Elite
Current Laptop:
Model: Asus ROG Zephyrus G14
CPU: Ryzen 9 5900HS
GPU: RTX 3060
RAM: 16GB @3200 MHz
Old PC:
CPU: Intel i7 8700K @4.9 GHz/1.315v
Mobo: Asus Prime Z370-A
https://linustechtips.com/topic/894547-7700hq-normal-load-temp/#findComment-11026167
