Sometimes, I'll turn on my PC, and it will just sit and display a black screen. No bios, nothing. I'll manually turn off the PC and turn it back on, and whoosh it works perfectly. Anyone know what might be causing this? And furthemore, why does a simple reset make such a difference when I'm not physically changing anything.
https://linustechtips.com/topic/894311-occasional-boot-problems/
What kind of machine, laptop, desktop, aio, tablet...
When you say turn off do you mean sleep mode, hibernate or any other features like this, or do you fully shut down the machine? This just seems like a wake issue to me, typically don't see machines do that from a completely powered down state.
CPU: i7-4770k @4.8ghz---Motherboard: Asus Sabertooth z97---Ram 32gb Corsair Vengeance---GPU: 2 EVGA GTX 980 4gb way sli---Case: Corsair 600T White---Storage: 500gb 850 Pro & WD Black 4tb---PSU: Corsair RM1000
I have this same issue. I have a desktop with the following specs:
Gigabyte fm2+  F2A88X-D3HP
AMD Athlon x4 860k
Sapphire Nitro rx460 4gb
kingston ssd, evga psu, 8gb corsair ram.
Like Friendlyyy said, when I turn my computer on sometimes it just displays a black screen. I simply hit the restart button and it usually just boots properly. It has done it twice in a row before. I would say this happens maybe 1/20 power on's. And has been happening for a few months.
Another thing to note is that my peripherals light up and all of the fans in my pc are spinning when it fails to startup.
Interested to see if anyone can solve this one. Thanks!
@Icuw1pc I have an Alienware x51 r2, I'm not sure if you need the specs but here they are anyways.
i7 4790 3.6 GHz
GTX 1060 6GB
16 GB DDR3
250GB SSD (boot drive)
2TB SATA
And by turn off, I mean truly turn off the PC with the power button, I don't really have any other options as I'm stuck on a screen with the Alienware logo and nothing else, or occasionally just a black screen. It's a full turn off, turn back on.
i7 4790 3.6 GHz
GTX 1060 6GB
16 GB DDR3
2TB SATA
Have you checked status's on BIOS revisions for your rig? It could be a firmware bug
Ran into this a few times, most of the time it ended up being a dieing component on the board
Might not be the case (hopefully)
I do remember some of them eventually dieing
The one I can remember well, turned out to be a dead board, it just sort of died slowly
But could be a number of things,
Maybe your psu has trouble getting it up ( bom chicka wa wa) with the initial power up sometimes, because its just not doing so well
Maybe a bios flash will fix it
Maybe a capacitor has popped on the motherboard ( look for bulging or bursted capacitors)
How often does it happen?
Can you reliably recreate the scenario, so we can try to come up with some tests?
First of all, I can reproduce it. It i were to turn my computer on and off, it happens around every 1/20 or 1/30 boots.
I made sure bios and everything was updated. All of my parts are still relatively new, just over a year old and the capacitors on the motherboard look fine. Also, the EVGA psu has more than enough juice to power the system (550w gold) and I spent a little extra on it just because I do intend to use it for a future build.
It would be unfortunate if parts did fail, I'm hoping it lasts a another year or so. Or at least until RAM prices come down because I would need a mobo, cpu and ram combo...
Well anyways, if it's not a simple fix ill probably just keep running it as is. It's only a minor inconvenience and if anything goes wrong, I have a laptop at least.
