4 minutes ago, sondrejr said:
1tb WD Black
YOU WILL LOOSE DATA THIS WAY SO BACKUP ANY IMPORTANT FILES
You have to plug it in to your computer, then go to Computer Management >  Then on the side, click on Disk Management > right click on the correct disk > then click on "Convert to GPT disk"
The picture will show you where exactly to right click
https://linustechtips.com/topic/894168-need-help-with-hdd/#findComment-11021625
After that, you will need to format the disk. (click on quick format)
https://linustechtips.com/topic/894168-need-help-with-hdd/#findComment-11021636
Are you trying to move it from one computer to another?
Main System: Phobos
AMD Ryzen 7 2700 (8C/16T), ASRock B450 Steel Legend, 16GB G.SKILL Aegis DDR4 3000MHz, AMD Radeon RX 570 4GB (XFX), 960GB Crucial M500, 2TB Seagate BarraCuda, Windows 10 Pro for Workstations/macOS Catalina
Secondary System: York
Intel Core i7-2600 (4C/8T), ASUS P8Z68-V/GEN3, 16GB GEIL Enhance Corsa DDR3 1600MHz, Zotac GeForce GTX 550 Ti 1GB, 240GB ADATA Ultimate SU650, Windows 10 Pro for Workstations
Older File Server: Yet to be named
Intel Pentium 4 HT (1C/2T), Intel D865GBF, 3GB DDR 400MHz, ATI Radeon HD 4650 1GB (HIS), 80GB WD Caviar, 320GB Hitachi Deskstar, Windows XP Pro SP3, Windows Server 2003 R2
https://linustechtips.com/topic/894168-need-help-with-hdd/#findComment-11021639
@IBM_THINKPAD_R51 @kb5zue Slow down guys.
11 minutes ago, sondrejr said:
My HDD is a legacy format I think, so it won’t boot into windows. How to I get it to a uefi??
Check your BIOS to see if there are any settings you can change to get it to work. It would be MBR/Legacy mode, or even Windows 7 compatibility mode. Or it could be that Windows was installed using a SATA controller in IDE mode, where a newer one would be set to ACHI by default.
https://linustechtips.com/topic/894168-need-help-with-hdd/#findComment-11021647
Do not confuse GPT/MBR with Legacy/UEFI
SPECS: Intel Core i5-4460 // PowerColor Red Dragon RX 480 4GB // 1x8GB DDR3 RAM // Delta 500AB-6A PSU // HyperX Cloud Stinger / Logitech G710+ / Logitech G502 / Xbox One Halo Guardian controller // LG 24M45H 1080p //
How to cope with depression
Spoiler free review of Life is Strange (Video Game)
https://linustechtips.com/topic/894168-need-help-with-hdd/#findComment-11021665
go to the BIOS and set the boot to legacy mode and SATA to IDE mode instead of AHCI mode and try again
ASUS X470-PRO • R7 1700 4GHz • Corsair H110i GT P/P • 2x MSI RX 480 8G • Corsair DP 2x8 @3466 • EVGA 750 G2 • Corsair 730T • Crucial MX500 250GB • WD 4TB
https://linustechtips.com/topic/894168-need-help-with-hdd/#findComment-11021677
Might not even have that function on a newer motherboard
https://linustechtips.com/topic/894168-need-help-with-hdd/#findComment-11021722
19 minutes ago, sondrejr said:
When I do that it’s locket on uefi
If you go to Advanced Settings>Windows OS Configuration
Then set:
Windows10 WHQL [Disabled]
Windows7 installation [Enabled]
Then go back to boot mode and the setting should allow you to set UEFI+Legacy
However if your Windows installation on your old computer wasn't  originally in AHCI mode it still won't work and probably the best solution is to reformat.
There is a way of changing it from IDE to AHCI but you would need to put it back in the old PC and do some fiddly things with drivers and registry values.
https://linustechtips.com/topic/894168-need-help-with-hdd/#findComment-11021870
Then set:
I don’t have an old pc
https://linustechtips.com/topic/894168-need-help-with-hdd/#findComment-11021906
Then set:
I changed motherboard because the pins we’re broken
https://linustechtips.com/topic/894168-need-help-with-hdd/#findComment-11021909
if you have your windows dvd just restore the system with it, that will install the AHCI drivers
https://linustechtips.com/topic/894168-need-help-with-hdd/#findComment-11021949
