8 hours ago, Ahoy Hoy said:
http://headphonespares.sennheiser.co.uk/portable-headphones/ie-80
did you even use google. Get it direct from sennheiser.
I don't want to get the stock cables lol. Don't mean to be rude but I wouldn't be coming to a forum if I wanted an obvious answer like buying it from them.
Just now, stevenchoi56 said:
Do you know of any companies that might be making some higher end cables?
Higher end cables for better sound? I don't think it will make a difference. Better quality materials and durability yes, but sound, i really don't think so..
Cpu R5 1600 @3.7ghz - MB Gigabyte AB350 Gaming 3 - RAM Corsair Vengeance LPX 8GBx2 @3000mhz - GPU Palit GTX 1070ti Dual - Storage Kingston FuryX 120GB SSD, WD 500GB Green HDD, Seagate 1TB HDD - PSU Seasonic X650 - Case Sharkoon S25-W - Display Zowie XL2411 - Peripherals Filco Ninja Browns, Zowie FK2 & Qck Hyperbeast Ed.
Yeah I am looking for something thats more durable and also just better quality overall. Where I live is pretty cold and the stock cables are just so bad and a nicer cable design and look would be nice too.
I'm not really into IEM's so no but just know that higher end cables only yield sonic improvements on paper. You're not going to hear a difference.
Though they can for sure be of better quality build wise.
Are there no cables that you liked on the page I linked ?
There is but just not the right colour haha. Trying for braided all black or possibly a mix of black and red.
Nevermind I managed to find one I like. Thanks for your help.
