5 minutes ago, Squee_z said:
I need a server with 3 TB and 32 GB ram or more for a small price... Linus should do a video on cheap storage servers. I've been looking into the DELL servers. And wow... DELL sells servers..
What purpose? 32GB is unnecessary for a file server.
Main Rig:-
Server:-
What is the server for? A file server doesn鈥檛 need 32GB of RAM.聽
Main System: Phobos
AMD Ryzen 7 2700 (8C/16T), ASRock B450 Steel Legend, 16GB G.SKILL Aegis DDR4 3000MHz, AMD Radeon RX 570 4GB (XFX), 960GB Crucial M500, 2TB Seagate BarraCuda, Windows 10 Pro for Workstations/macOS Catalina
Secondary System: York
Intel Core i7-2600 (4C/8T), ASUS P8Z68-V/GEN3, 16GB GEIL Enhance Corsa DDR3 1600MHz, Zotac GeForce GTX 550 Ti 1GB, 240GB ADATA Ultimate SU650, Windows 10 Pro for Workstations
Older File Server: Yet to be named
Intel Pentium 4 HT聽(1C/2T), Intel D865GBF, 3GB DDR 400MHz, ATI Radeon HD 4650 1GB (HIS), 80GB WD Caviar, 320GB Hitachi Deskstar, Windows XP Pro SP3, Windows Server 2003 R2
Ebay. Look for Dell R510 servers. They're reasonably cheap and you can get stupid amounts of DDR3 registered ECC memory for really cheap. Companies are upgrading to new hardware so there's tons of the DDR3 stuff on the market.
You can also look at just building a small computer with lower end server grade hardware. That's basically what I did for my storage server. Xeon E3 Gen 3 with a Host Bus Adaptor (HBA) card and then I'm running FreeBSD (The OS FreeNAS is based on) and using ZFS. You can also virtualize if that's what you're planning to use the memory for by using virtual box.
Just now, Name Taken said:
The Dell PowerEdge R710 is one of cheapest and most the most readily available servers.
If they're aiming for 32GB and don't need a ton of processing, the R510 can be found for less and is fairly easy to find used as well. Both are 2U and the 510 generally has higher storage capacity options like 8 bay since companies use them as NAS systems with mild services being run as well.聽
On the other side of the fence:
HP DL360 G6 or G7
HP DL380 G6 or G7
HP ML350 G6
Pretty much equal to the mentioned Dell servers. Same platform, imo better remote management though. Not using HP firmware on your drives will make you go deaf however :P
PC Specs -聽AMD Ryzen 7 5800X3D聽-聽MSI B550M Mortar聽- 32GB Corsair Vengeance RGB DDR4-3600 @ CL16 - ASRock RX7800XT聽-聽660p 1TBGB & Crucial P5 1TB -聽Fractal Define Mini C -聽CM V750v2聽- Windows 11 Pro
8 minutes ago, Name Taken said:
On the downside, they are loud, uses alot of electricity, takes up alot of space if not using a rack, and uses decade old Nehalem era CPU which is why they are all over the used market.
A server using Nehalem or Westmere CPUs will use about 100W idle. Source: my 12-core, 80GB RAM DL380G7 with 8 15K SAS disks :P
So it's really not THAT bad. Older Harpertown and Clovertown Xeons combined with FBDIMM DDR2 is the real global warming architecture :P聽 easily 200-250W idle.
True. But if you want any kind of new hardware on a pre-built server, you're going to be hurting in the wallet. Also there are some low power use 5600 series CPUs which would make it not too bad.聽
I started a thread yesterday about a very inexpensive 1U I found.聽 I don't have first hand experience on it at this time since it's still in transit.
You can find E5 v1 chips for very, very cheap.聽 Same goes for DDR3 rdimm memory.
May need to consider an SFP to RJ45 module though.
