Yes. What kind of hardware are we talking about here?
PC Specs - AMD Ryzen 7 5800X3D MSI B550M Mortar - 32GB Corsair Vengeance RGB DDR4-3600 @ CL16 - ASRock RX7800XT 660p 1TBGB & Crucial P5 1TB Fractal Define Mini C CM V750v2 - Windows 11 Pro
https://linustechtips.com/topic/893775-power-draw-with-oc/#findComment-11016888
2 minutes ago, The321 said:
Gtx 6200 se turbocashe @NelizMastr
GTX? Lolno, that's a Geforce 6200 from 2004 with shared system memory (that's the "turbo" part). It won't draw a lot of power nor will it be worth it to OC, unless you run Windows 98 games on it.
https://linustechtips.com/topic/893775-power-draw-with-oc/#findComment-11016893
1 minute ago, The321 said:
@NelizMastr it's for emulations nothing too fancy soo I could oc it to the max on my 300w psu athlon 4200+ inside also 2gb ram
It won't help since you're bottlenecked by the memory speed. It'll run PS1/N64 and older consoles fine emulation wise.
https://linustechtips.com/topic/893775-power-draw-with-oc/#findComment-11016904
39 minutes ago, The321 said:
Soo the ram frequencie Is maximum memory or core frequentie that' useful ?  @NelizMastr
You're overthinking this too much. It's an entry level card that came out 14 years ago. There won't be a very noticeable difference either way.
https://linustechtips.com/topic/893775-power-draw-with-oc/#findComment-11016996
