Ever since I've upgraded to a GTX 1050ti (yes, super budget, I know,) from an ancient ATI Radeon HD4870 I have been having an issue with everything on my screen appearing slightly blurred, which didn't happen with my old card.
It's at 1920x1080 at 60hz, the native resolution, and I've tried tweaking the nvidia control panel to no avail. Does anyone know what the issue is/how to fix it?
https://linustechtips.com/topic/893357-blurry-screen-issue-1050ti/
Go to your monitor settings and look for a setting called "Sharpness". Fiddle with that for a bit. Hopefully this solves the issue, it did for me.
Alternatively try setting different resolutions, then going back to 1080p
We have a NEW and GLORIOUSER-ER-ER PSU Tier List Now. (dammit @LukeSavenije stop coming up with new ones)
You can check out the old one that gave joy to so many across the land here
Computer having a hard time powering on? Troubleshoot it with this guide. (Currently looking for suggestions to update it into the context of <current year> and make it its own thread)
Computer Specs:
Mathresolvermajig: Intel Xeon E3 1240 (Sandy Bridge i7 equivalent)
Chillinmachine: Noctua NH-C14S
Framepainting-inator: EVGA GTX 1080 Ti SC2 Hybrid
Attachcorethingy: Gigabyte H61M-S2V-B3
Infoholdstick: Corsair 2x4GB DDR3 1333
Computerarmor: Silverstone RL06 "Lookalike"
Rememberdoogle: 1TB HDD + 120GB TR150 + 240 SSD Plus + 1TB MX500
AdditionalPylons: Phanteks AMP! 550W (based on Seasonic GX-550)
Letterpad: Rosewill Apollo 9100 (Cherry MX Red)
Buttonrodent: Razer Viper Mini + Huion H430P drawing Tablet
Auralnterface: Sennheiser HD 6xx
Liquidrectangles: LG 27UK850-W 4K HDR
Thanks, that worked :) don't know why I didn't think of that in the first place
You can mark the thread solved to let people know you've solved your issue :)
Click on the checkmark on any post in the thread and it'll show that as the "solution"
Computer Specs:
