Hello guys,
I'm having a bit of trouble with a PC I've built for my brother. I've tried quite a few things to amend the problem but I just can't seem to fix it. It's a bit lengthy, but any advise would be appreciated.
Spec
  • i7 7700k
  • ASUS Z270-P
  • BeQuiet SRS Cooler
  • Kingston Hyper X Fury RAM 32GB
  • Samsung 850 EVO 500GB
  • Seagate Firecuda 1TB
  • MSI GTX1080 Factory OC
  • TPLink triple antenna Wireless Card (can't remember the exact model)
  • BeQuiet Pure Power 10 PSU
  • Fractal Define R5 Case
  • ASUS CD/DVD Writer
The Problem
I'm getting intermittent output, and boot problems.
When installing Windows, the machine required a restart, however upon restart I got no output on the screen. The only way to resolve this was to hold down the power to shut the machine down, however by doing this it came up with the 'American Megatrends' screen, outlining a shut down error, and that the machine didn't post correctly.
Take note - this started on first boot up when installing windows.
I managed to get Windows installed, by plugging in the SSD into my own machine, and installing it from there.
Today the machine runs perfectly when in Windows - it passed all the stress tests, and I can Game & make Music on it without any issues, it works just as it should, however, I'm still having this booting problem.
30% of the time, the machine boots up fine, no issues whatsoever, however every other time I instantly get the American Megatrends screen showcasing the shutdown and post error (despite shutting down correctly), or no output, forcing me to hold the power button down, and then we're back to square one.
The way I can boot into Windows is by manually selecting the boot drive from within the BIOS.
What I've tried so far
I've tried everything I can think of to resolve this, but I'm still having this issue. I've outlined what I've done below.
  • Cleared the CMOS - removed the battery etc.
  • Removed all PCI cards and external devices, leaving me with just the keyboard, mouse & monitor, using the on-board graphics (the error occurs with the GPU or on-board).
  • Re-seated the GPU in case this caused the output error
  • The case headers are all on the correct pins.
Any advise or preferable a solution would be much appreciated!
Thanks
https://linustechtips.com/topic/892453-help-boot-posting-error-and-no-output/
Update the Bios.
Make sure ram and all cards are seated correctly.
MSI MAG X670E TOMAHAWK WIFI Motherboard, AMD Ryzen 9 7900X3D Desk-top Processor (12-core/24-thread, 140MB cache, up to 5.6 GHz max boost), CORSAIR VENGEANCE DDR5 RAM 32GB (2x16GB) 6000MHz CL30 AMD EXPO iCUE Compatible Computer Memory, Samsung 990 PRO NVMe M.2 SSD, 2 TB, PCIe 4.0, 7,450 MB/s read, 6,900 MB/s write, Internal SSD, 2 x Seagate BarraCuda 4 TB Internal Hard Drive HDD – 3.5 Inch SATA 6 Gb/s 5400 RPM 256 MB Cache for Computer Desktop PC Laptop (ST4000DM004), MSI MPG A1000G PCIE5 Power Supply Unit, UK Plug - 1000W, 80 Plus Gold Certified, Fully Modular ATX 3.0, PCIe 5.0 GPU, XILENCE XC982 LQ240PRO AIO COOLER, XFX Speedster MERC 310 AMD Radeon RX 7900 XT 20GB 1 x AOC CU34G2XE & 1 x Samsung U32J59XUQ 3840 x 2160 4K, 1 x Samsung Evo 970 Evo Plus NVME PCI-E 1TB, 1 x Samsung Evo 850 250GB, 1 X Sandisk Ultra II SSD 240GB + 2 X 4TB Seagate Barracuda SATA III,  MZHOU 7 Ports PCIe USB 3.0 Card,  2 x UGREEN Hard Drive Enclosure 3.5 inch External SATA Disk Caddy Reader USB 3.0 2.5 3.5 HDD SSD 16TB UASP Case Dock Station With 12V 2A Power Adapter For Windows with 6TB Seagate Barracuda SATA III, Fractal Design Pop XL Case + 4 Fractal Design 140mm Case Fans, Logitech MX Vertical & MX Ergo Trackball Mouse using same USB unifying device, Microsoft Ergonomic Keyboard, Windows 11 Pro x64 Retail, 6TB Seagate USB 3.0 Backup Plus Hub, Blue Yeti Microphone, Logitech C922 Pro HD,  Logitech C920 Pro HD, Bit Defender Total Security 2021.
Second PC (Cyclops) - MSI 990FXA Gaming, AMD FX 8370 4Ghz, Corsair 16GB Vengeance Red 9-9-9-24 1600Mhz, Arctic Cooling Freezer 13, Asus Strix 1050TI 4GB, 1 X Acer 27" Full HD Monitor, 1 X Sandisk Ultra II SSD 240GB, 1 x Samsung Evo 850 250GB, 2 X Seagate Barracuda 2TB, 1 X WD Black 2TB, 1 x ASUS 16x DVDRW, X-Case Eagle III Case, 3 X Corsair AF 120 Case Fans, EVGA 850 G2 80+ Gold + PSU, Logitech MX Master Mouse, Corsair K30 Keyboard, Logitech C920 Webcam, R0DE NT1-A Microphone, Scarlet 212 Audio Interface (Revision 2), Windows 10 Pro X64 Retail, Bit Defender Total Security 2021, 2TB Seagate Expansion USB Hard Drive.
Third PC (Old Trustie) - Acer Aspire M3400, OEM Mainboard, AMD FX Athlon II X3 425 2.7Ghz, 16GB Corsair Value 1600Mhz Ram, OEM CPU Cooler, AMD R7 260 2GB GPU, 1 X Acer 27" Full HD Monitor, 1 X Sandisk Ultra II SSD 240GB, 2TB Samsung SATA III, 1 X OEM 16X DVDRW, 1 X Acer OEM Case, 1 X Corsair AF120 Case Can, Corsair CX500 Bronze+ CPU, Logitech MX Master Mouse, Corsair K30 Keyboard, Windows 10 Home X64 OEM, Logitech C920 Webcam, Bit Defender Total Security 2021.
Printers Include - Canon MG5750, Canon, IP8750,  Canon Pixma Mega tank G5050 & 2 X Samsung Xpress C410W.
1 X Zexrow Xbox360 Wired Game Controller.
TP Link Archer AX6000 Cable Router Wifi6 with a Virgin Media Hub 4.0 in Modem only mode running 1GB Fibre internet.
Samsung Galaxy S21+ 256GB Mobile Phone.
Internet Speed.....
https://www.speedtest.net/result/9935039193
