Decision between hdd's
6 minutes ago, D148xZ said:I believe this is the smart data, does it all check out?
500gb HDD
*** DiskCheckup V3.4 Build: 1003 Report ***
SysInfo DLL Version: SysInfo v1.0 Build: 1122
Time of export: 16:56:39 02-feb-2018Device information:
Device ID: 0
Interface: SATA
Device Capacity: 476937 MB
Serial Number: S2AKNMSF
Model Number: ST500DM002-1BD142SMART ATTRIBUTES:
ID Description Status Value Worst Threshold Raw Value TEC
1 Raw Read Error Rate OK 111 99 6 5448 N/A
3 Spin Up Time OK 100 97 0 0 N/A
4 Start/Stop Count OK 99 99 20 1861 N/A
5 Reallocated Sector Count OK 100 100 36 0 N/A
7 Seek Error Rate OK 85 66 30 398526773 N/A
9 Power On Time OK 64 64 0 31579 N/A
10 Spin Retry Count OK 100 100 97 0 N/A
12 Power Cycle Count OK 100 100 20 27 N/A
183 SATA Downshift Error Count OK 100 100 0 0 N/A
184 End-to-End error OK 100 100 99 0 N/A
187 Reported Uncorrectable Errors OK 100 100 0 0 N/A
188 Command Timeout OK 100 98 0 1339 N/A
189 High Fly Writes OK 100 100 0 0 N/A
190 Temperature Difference from 100 OK 80 42 45 7954615828500 N/A
194 Temperature OK 20 58 0 20 C N/A
195 Hardware ECC Recovered OK 42 29 0 5448 N/A
197 Current Pending Sector Count OK 100 100 0 0 N/A
198 Uncorrectable Sector Count OK 100 100 0 0 N/A
199 UltraDMA CRC Error Count OK 200 200 0 0 N/A
240 Head flying hours OK 100 253 0 227654741526628 N/A
241 Total LBAs Written OK 100 253 0 2017593533 N/A
242 Total LBAs Read OK 100 253 0 3489302545 N/A
320gb HDD
Time of export: 16:56:48 02-feb-2018Device information:
Device ID: 3
Interface: SATA
Device Capacity: 305242 MB
Serial Number: 9QFADXP0
Model Number: ST3320620ASSMART ATTRIBUTES:
1 Raw Read Error Rate OK 100 253 6 0 N/A
3 Spin Up Time OK 95 95 0 0 N/A
4 Start/Stop Count OK 94 94 20 6850 N/A
7 Seek Error Rate OK 84 60 30 254171939 N/A
9 Power On Time OK 96 96 0 3682 N/A
12 Power Cycle Count OK 99 99 20 1831 N/A
190 Temperature Difference from 100 OK 77 52 45 386793495 N/A
194 Temperature OK 23 48 0 23 C N/A
195 Hardware ECC Recovered OK 65 54 0 103317686 N/A
200 Write Error Count OK 100 253 0 0 N/A
202 Data Address Mark Errors OK 100 253 0 0 N/A
Both actually look quite good.
No Reallocated Sectors, which is the biggest flag of a dying HDD. A few raw read errors on the 500GB drive, but that can be caused by anything, such as a corrupted file, so that's not necessarily indicative of much.
The 320GB drive looks to have slightly less wear, overall, but both are in "Good" health. Though a HDD can drop dead on you without warning - but there's no signs that either of these will die anytime soon.
If you don't need the extra space, use the 320GB drive. But if you need that extra space, the 500GB drive should be okay.
