I need help
Go to solution Solved by Barend,
I just would like a straight answer about what the problem is and what I could do to fix it.
My PC:
CPU: Intel - Core i5-7600K 3.8GHz Quad-Core Processor
CPU Cooler: Cooler Master - Hyper TX3 Evo 43.1 CFM CPU Cooler
Motherboard: Asus - STRIX Z270H ATX LGA1151 Motherboard
Memory: Crucial - Ballistix Sport LT 16GB (2 x 8GB) DDR4-2400 Memory
Storage: Western Digital - Blue 500GB 2.5" Solid State Drive
Video Card: KFA2 - GeForce GTX 1080 8GB Video Card
Case: Cooler Master - MasterBox Lite 5 ATX Mid Tower Case
Power Supply: Cooler Master - 650W 80+ Bronze Certified Semi-Modular ATX Power Supply
GPU set to prefer maximum performance. And high quality.
I have really low fps in game with my gtx1080.
Build:
16gb ram ddr4 2400mhz
650watt
Gtx Kfa2 EXOC 1080
I5 7600k 3.8 ghz
Wdblue 500gb ssd
Please contact me or mail me or discord me. Check my system or task manager with me... I just want to know what I should do to fix it.
https://linustechtips.com/topic/892093-i-need-help/
What FPS are you getting and im which game? You could ne facing a bottleneck here since i5 7600k is not up on par with a GTX 1080.
SPECS: Intel Core i5-4460 // PowerColor Red Dragon RX 480 4GB // 1x8GB DDR3 RAM // Delta 500AB-6A PSU // HyperX Cloud Stinger / Logitech G710+ / Logitech G502 / Xbox One Halo Guardian controller // LG 24M45H 1080p //
How to cope with depression
Spoiler free review of Life is Strange (Video Game)
https://linustechtips.com/topic/892093-i-need-help/#findComment-10999432
I play: GTA, ARK, WILDLANDS OVERWATCH, ELDER SCROLLS ONLINE,.
Around the 40 fps some times it 's 80+ but mostly between 40 and 60. Which is not normal for a 1080 I guess
https://linustechtips.com/topic/892093-i-need-help/#findComment-10999435
Which resolution? 1080p? 1440p? 4K? 5K? 8K? 401K?
PC Specs - AMD Ryzen 7 5800X3D MSI B550M Mortar - 32GB Corsair Vengeance RGB DDR4-3600 @ CL16 - ASRock RX7800XT 660p 1TBGB & Crucial P5 1TB Fractal Define Mini C CM V750v2 - Windows 11 Pro
https://linustechtips.com/topic/892093-i-need-help/#findComment-10999461
The only reason you might be getting those low fps might be because of
1. bottlenecking
or
2. you have not updated your drivers in the nvidia geforce experience app
Try configuring stuff in the nvidia control panel too, like the power management mode or the 3d render settings ( performance, balanced or quality )
https://linustechtips.com/topic/892093-i-need-help/#findComment-10999502
1. bottlenecking
or
Drivers are up to date power is set to maximal performance and what settings could I further adjust?
https://linustechtips.com/topic/892093-i-need-help/#findComment-10999530
Check your temperatures and clock speeds using msi afterburner/rivatuner during gameplay. For reference, with settings mostly maxed, I get around 100fps in GTA V @ 1080p with a GTX1060 6GB.
https://linustechtips.com/topic/892093-i-need-help/#findComment-10999558
How did you came up to this statement? Since when that i5 bottlenecks a 1080 so badly that you'd get low FPS in the games he mentioned?
No, it is not normal. As NelizMastr said, check the temperatures you get during playing. Also, if possible could you install CAM software from NZXT to check the usage as well.
This is funny as lately a lot of people had bad experience with their GTX 1080, including myself. I Started to get FPS dips constantly. Didn't happened before. Didn't had time to investigate but my temperatures are in check. usage kind of jumps around - from no more that 80% now to 90-98%.
CPU: Ryzen 7 2700x, Cooling: Corsair H100i Platinum AIO MOBO: Asus Strix B450 F GPU: Gigabyte GTX 1080 Founders Edition + Arctic Accelero Xtreme III RAM: 2x8GB ThermalTake ToughRAM White 3200MHz PSU: Corsair RM850x White Storage: 250GB Samsung 970 Evo NVMe CASE: Corsair 275r Airflow White OTHER: White and Orange Cable Extensions ---- MONITOR: Samsung LC32JG5 32" WQHD 1440p VA 144Hz
https://linustechtips.com/topic/892093-i-need-help/#findComment-10999574
I'll make a photo of my temptures and clock speeds while in gta
https://linustechtips.com/topic/892093-i-need-help/#findComment-10999651
A sub 4 ghz quad core could easily bottleneck something like a 1080, especially if there are more background tasks running.
OP, what specific game settings are you using? What cpu usage like while gaming?
On 2/1/2018 at 3:24 AM, Barend said:
I've been trying to use super sampling too. That doesn't work
That would make it worse since you're basically running at a higher res
Make sure to quote me or tag me when responding to me, or I might not know you replied! Examples:
Do this:
Quote
And make sure you do it by hitting the quote button at the bottom left of my post, and not the one inside the editor!
Or this:
@DocSwag
Buy whatever product is best for you, not what product is "best" for the market.
Interested in computer architecture? Still in middle or high school? P.M. me!
I love computer hardware and feel free to ask me anything about that (or phones). I especially like SSDs. But please do not ask me anything about Networking, programming, command line stuff, or any relatively hard software stuff. I know next to nothing about that.
Compooters:
Desktop:
CPU: i7 6700k, CPU Cooler: be quiet! Dark Rock Pro 3, Motherboard: MSI Z170a KRAIT GAMING, RAM: G.Skill Ripjaws 4 Series 4x4gb DDR4-2666 MHz, Storage: SanDisk SSD Plus 240gb + OCZ Vertex 180 480 GB + Western Digital Caviar Blue 1 TB 7200 RPM, Video Card: EVGA GTX 970 SSC, Case: Fractal Design Define S, Power Supply: Seasonic Focus+ Gold 650w Yay, Keyboard: Logitech G710+, Mouse: Logitech G502 Proteus Spectrum, Headphones: B&O H9i, Monitor: LG 29um67 (2560x1080 75hz freesync)
Home Server:
CPU: Pentium G4400, CPU Cooler: Stock, Motherboard: MSI h110l Pro Mini AC, RAM: Hyper X Fury DDR4 1x8gb 2133 MHz, Storage: PNY CS1311 120gb SSD + two Segate 4tb HDDs in RAID 1, Video Card: Does Intel Integrated Graphics count?, Case: Fractal Design Node 304, Power Supply: Seasonic 360w 80+ Gold, Keyboard+Mouse+Monitor: Does it matter?
Laptop (I use it for school):
Surface book 2 13" with an i7 8650u, 8gb RAM, 256 GB storage, and a GTX 1050
And if you're curious (or a stalker) I have a Just Black Pixel 2 XL 64gb
https://linustechtips.com/topic/892093-i-need-help/#findComment-11003172
Running the highest settings in most games
1920x1080 vsync on 144hz
https://linustechtips.com/topic/892093-i-need-help/#findComment-11003526
Check CPU usage while gaming. If it's in the high 80s to 90s, it's likely a CPU bottleneck.
Do this:
Quote
Or this:
@DocSwag
Compooters:
Desktop:
Home Server:
https://linustechtips.com/topic/892093-i-need-help/#findComment-11004966
Well actually its most of the time my GPU running in the 80 - 90s. Like it did today with TESO (elder scrolls  online) and than 'my cpu is between 50% -  70%. And than my GPU also returns to 50% - 70%.....?
https://linustechtips.com/topic/892093-i-need-help/#findComment-11015093
My PC:
https://linustechtips.com/topic/892093-i-need-help/#findComment-11015106
Just want to confirm it's not something weird with the games... Could you try running something like unigine heaven and showing me what your scores are?
Do this:
Quote
Or this:
@DocSwag
Compooters:
Desktop:
Home Server:
https://linustechtips.com/topic/892093-i-need-help/#findComment-11017325
