You could use firefox :P
seriously though, clean cookies, update, re-install would be the most common steps for troubleshooting these sort of silly "bugs"
Personal Desktop":
Luna, the temporary Desktop:
https://linustechtips.com/topic/891486-how-to-fix/#findComment-10993089
6 minutes ago, techcuriosity said:
Hi, I have problem with my google chrome, the point is that every single time I close chrome and open it again, I should login to google account as well again. I should do it over and over. Anyone encountered with that? If so, how you fixed this?
1. Click the menu icon and go to settings
2. Click "Show advanced settings"
3. In "Privacy", click "Clear browsing history"
4. Check "Cookies and other site and plugin data" and choose "the beginning of time" in drop-down box, then click "Clear browsing history"
5. Go to https://accounts.google.com/serviceloginauth, type your Gmail address and click "Next"
6. Check "Stay sign in" and type your password to log in.
Give this a try.
https://linustechtips.com/topic/891486-how-to-fix/#findComment-10993090
Give this a try.
I have tried to clean browsing history, cache and cookies, also tried reinstall chrome, didn't work, this your link https://accounts.google.com/serviceloginauth doesn't open, 404error. , on https://myaccount.google.com/  I can't find any option to type my Gmail address..
https://linustechtips.com/topic/891486-how-to-fix/#findComment-10993144
So it is...
Try Settings>Privacy and Security>Content Settings>Cookies and make sure Keep local data only until you quit your browser is NOT turned on.  After that I am about tapped out on ideas.
https://linustechtips.com/topic/891486-how-to-fix/#findComment-10993180
