1080ti Low Usage
Go to solution Solved by Shiftstealth,
As others have stated this is related to your Ryzen (I have one myself!). Due to the clockspeed utilization is going to be lower than an intel system with a higher clockspeed. The good news is when Ryzen 2 (Not Ryzen + in a few months) comes out you should be able to grab one of those that will clock fairly high, and resolve this issue. (7nm GloFo is quoting 5Ghz+ i don't believe we'll see 5Ghz+, but it will be better than 3.8Ghz)
Hey so I just upgraded my Video Card to a 1080ti (from a Radeon R9 290) a few days ago and I was wondering if anyone here could help with something.
To start off here's my PC: https://pcpartpicker.com/user/KeanMorris/saved/#view=VGnJVn
I have a 2560x1080 75 hz ultrawide monitor (freesync).
I have my CPU at 3.8 ghz and my ram is running at 2933 (unstable at any higher and I don't really know how to mess with RAM settings..)
I first noticed this issue when playing Overwatch on low settings. In the beginning my FPS was going straight to the cap of 300 but then I noticed it kind of
fluctuated and went down a bit (going down to like 250, sometimes lower; including a couple times it went down to 180 for a little bit).
I thought this was weird so I started watching the usage in HWMonitor only to find that my GPU's utilization was starting out at 99 percent and then going
down to roughly 50-60 and then constantly changing to values in-between. The utilization also seem to go down if I started recording with OBS,
which doesn't make much sense to me as even when I'm playing OW and recording my CPU usage is still only at like 40 percent.
Then I set my graphics set all the way up to epic and it seems to run fine; it doesn't hit 300 FPS but the
utilization seems to stay at 99 and I get around 250 FPS. However NOW I have (or I just noticed that I have) quite a bit of screen tearing that I can't seem to fix no matter what I do,
and while it isn't unplayable, it is certainly annoying....
But back to the GPU utilization, the same exact thing seems to happen when I play Doom. GPU utilization stays around 50-60 percent all the time. Ill put a clip that I recorded at the end showing this.
Some other games seem to be fine from what little bit I've played; Witcher 3 and Just Cause 3 on ultra run pretty similarly at around 90-120 FPS, and the GPU utilization stays at 97 percent.
Googling around I've read some posts and things from people who have a similar problem but I never really saw a definitive solution...
Anyway sorry for the gigantic novel of a post but I figured its best to provide as much info as possible. Also thanks in advance to anyone who helps, and here's the Doom video:
https://linustechtips.com/topic/891314-1080ti-low-usage/
as long as you're not dipping below 75 you're good
Ryzen 5 3600 stock | 2x16GB C13 3200MHz (AFR) | GTX 760 (Sold the VII)| ASUS Prime X570-P | 6TB WD Gold (128MB Cache, 2017)
Samsung 850 EVO 240 GB
138 is a good number.
https://linustechtips.com/topic/891314-1080ti-low-usage/#findComment-10991341
a ryzen at 3.8 cannot fully utilize a 1080 ti above a certain frame rate depending on the game, gonna guess anywhere 100+ fps, it's a cpu bottleneck.
5950x 1.33v 5.05 4.5 88C 195w ll R20 12k ll drp4 ll x570 dark hero ll gskill 4x8gb 3666 14-14-14-32-320-24-2T (zen trfc)  1.45v 45C 1.15v soc ll 6950xt gaming x trio 325w 60C ll samsung 970 500gb nvme os ll sandisk 4tb ssd ll 6x nf12/14 ippc fans ll tt gt10 case ll evga g2 1300w ll w10 pro ll 34GN850B ll AW3423DW
9900k 1.36v 5.1avx 4.9ring 85C 195w (daily) 1.02v 4.3ghz 80w 50C R20 temps score=5500 ll D15 ll Z390 taichi ult 1.60 bios ll gskill 4x8gb 14-14-14-30-280-20 ddr3666bdie 1.45v 45C 1.22sa/1.18 io  ll EVGA 30 non90 tie ftw3 1920//10000 0.85v 300w 71C ll  6x nf14 ippc 2000rpm ll 500gb nvme 970 evo ll l sandisk 4tb sata ssd +4tb exssd backup ll 2x 500gb samsung 970 evo raid 0 llCorsair graphite 780T ll EVGA P2 1200w ll w10p ll NEC PA241w ll pa32ucg-k
prebuilt 5800 stock ll 2x8gb ddr4 cl17 3466 ll oem 3080 0.85v 1890//10000 290w 74C ll 27gl850b ll pa272w ll w11
https://linustechtips.com/topic/891314-1080ti-low-usage/#findComment-10991356
Main PC: i7 8700K @ 4.9Ghz | Corsair H110i V2 |  ASUS Prime Z370-A  | Corsair Carbide 540 | EVGA GTX 1080 Ti SC2 | 16GB G.Skill Flare X @ 3200Mhz | 500GB Samsung 960 Evo | Seasonic Prime Ultra 650W | Dell S2417DG
https://linustechtips.com/topic/891314-1080ti-low-usage/#findComment-10991708
Even CPU usage is 40% or whatever, I'm pretty sure its a CPU bottleneck. The R7 has more threads than most games know what to do with, so the CPU is being underutilized, therefore; low CPU usage. To push  more frames, you'll need higher clockspeed.
Share any interests with me? Feel free to message me just to chit chat about whatever.
(Music) Depeche Mode, The Cure, Pink Floyd, Nick Cave and the Bad Seeds, Cocteau Twins, MGMT, Boy Harsher, The Smiths, Drab Majesty, Chelsea Wolfe, Carly Rae Jepsen, The Smashing Pumpkins, Virgin Prunes, Sky Ferreira, London After Midnight, Jonathan Coulton, Alvvays, Clan of Xymox, Bauhaus, Siouxsie and the Banshees, Anna Von Hausswolff, Joy Division, Sisters of Mercy, She Wants Revenge, The Frozen Autumn, My Bloody Valentine, Type O Negative, The Birthday Party, Leonard Cohen, Switchblade Symphony, Metallica, Creedance Clearwater Revival, Eagles, Elton John, Billy Joel.
(Games) PUBG, Metro Series, Command and Conquer games, Warhammer 40,000 games, Company of Heroes (2), RDR2, CoD4
(Other) Going to the goth club, Firearms, Building PCs (Especially budget PC builds), Playing instruments (Guitar, Piano APP for PC, Otamatone, Trombone) Camping, Board Games
https://linustechtips.com/topic/891314-1080ti-low-usage/#findComment-10992072
Slightly off topic:
You have a 75hz monitor? Why wouldn't you cap the framerate at 75 so you're not wasting power?
The screen tearing is because your frame-rate is above 75fps. Cap it at 75 and you won't get tearing (the free-sync doesn't help at all with a 1080Ti and even if it did it wouldn't help above 75hz anyway).
Primary PC-
CPU: Intel i7-6800k @ 4.2-4.4Ghz   CPU COOLER: Bequiet Dark Rock Pro 4   MOBO: MSI X99A SLI Plus   RAM: 32GB Corsair Vengeance LPX quad-channel DDR4-2800  GPU: EVGA GTX 1080 SC2 iCX   PSU: Corsair RM1000i   CASE: Corsair 750D Obsidian   SSDs: 500GB Samsung 960 Evo + 256GB Samsung 850 Pro   HDDs: Toshiba 3TB + Seagate 1TB   Monitors: Acer Predator XB271HUC 27" 2560x1440 (165Hz G-Sync)  +  LG 29UM57 29" 2560x1080   OS: Windows 10 Pro
Album
Other Systems:
Home HTPC/NAS-
CPU: AMD FX-8320 @ 4.4Ghz  MOBO: Gigabyte 990FXA-UD3   RAM: 16GB dual-channel DDR3-1600  GPU: Gigabyte GTX 760 OC   PSU: Rosewill 750W   CASE: Antec Gaming One   SSD: 120GB PNY CS1311   HDDs: WD Red 3TB + WD 320GB   Monitor: Samsung SyncMaster 2693HM 26" 1920x1200 -or- Steam Link to Vizio M43C1 43" 4K TV  OS: Windows 10 Pro
Offsite NAS/VM Server-
CPU: 2x Xeon E5645 (12-core)  Model: Dell PowerEdge T610  RAM: 16GB DDR3-1333  PSUs: 2x 570W  SSDs: 8GB Kingston Boot FD + 32GB Sandisk Cache SSD   HDDs: WD Red 4TB + Seagate 2TB + Seagate 320GB   OS: FreeNAS 11+
Laptop-
CPU: Intel i7-3520M   Model: Dell Latitude E6530   RAM: 8GB dual-channel DDR3-1600  GPU: Nvidia NVS 5200M   SSD: 240GB TeamGroup L5   HDD: WD Black 320GB   Monitor: Samsung SyncMaster 2693HM 26" 1920x1200   OS: Windows 10 Pro
Having issues with a Corsair AIO? Possible fix here:
Are you getting weird fan behavior, speed fluctuations, and/or other issues with Link?
Are you running AIDA64, HWinfo, CAM, or HWmonitor? (ASUS suite & other monitoring software often have the same issue.)
Corsair Link has problems with some monitoring software so you may have to change some settings to get them to work smoothly.
-For AIDA64: First make sure you have the newest update installed, then, go to Preferences>Stability and make sure the "Corsair Link sensor support" box is checked and make sure the "Asetek LC sensor support" box is UNchecked.
-For HWinfo: manually disable all monitoring of the AIO sensors/components.
-For others: Disable any monitoring of Corsair AIO sensors.
That should fix the fan issue for some Corsair AIOs (H80i GT/v2, H110i GTX/H115i, H100i GTX and others made by Asetek). The problem is bad coding in Link that fights for AIO control with other programs. You can test if this worked by setting the fan speed in Link to 100%, if it doesn't fluctuate you are set and can change the curve to whatever. If that doesn't work or you're still having other issues then you probably still have a monitoring software interfering with the AIO/Link communications, find what it is and disable it.
https://linustechtips.com/topic/891314-1080ti-low-usage/#findComment-10994611
2 hours ago, pyrojoe34 said:
Slightly off topic:
I've tried that already :S the tearing for some reason gets worse when I cap the FPS. When its higher it is much less noticeable but if I look closely I can still see it. It seems no matter what I do it doesn't fully go away.
I also have to keep free sync turned on because if it is off than my monitor won't run at 75hz.
https://linustechtips.com/topic/891314-1080ti-low-usage/#findComment-10994977
I haven't had any problems at just 60Hz, I run a GTX 780 on a FreeSync monitor. Unless the games you play actually need a higher refresh rate in order to get higher scores or something, I'd turn FreeSync off and let it run at 60Hz.
https://linustechtips.com/topic/891314-1080ti-low-usage/#findComment-10994994
True. I guess its not that big of a difference; I just would prefer 75 if possible. For now I am actually running it at 60 though because my smaller second monitor is 60 and having two different refresh rate monitors makes everything feel choppy; even dragging a file explorer window around. I guess I didn't notice this before because I think freesync fixed this (at least on my main monitor) when I was able to use it on my old card. I plan on getting a 75hz monitor to replace my second one so then I'll have matching refresh rates.
Also small update on the Doom thing: I changed the API setting in Doom from OpenGL to Vulkan and now I have much higher FPS (stays at 200 pretty consistently with some dips to 180 now and then) and higher GPU utilization... So that kind of fixed that I guess :).
https://linustechtips.com/topic/891314-1080ti-low-usage/#findComment-10995035
