some are optimised for low light, some for optical clarity, some are zoom some are for focus, some are for 3D photos... all kinds of reasons.
[FS][US] Corsair H115i 280mm AIO-AMD $60+shipping
System specs:
Asus Prime X370 Pro - Custom EKWB CPU/GPU 2x360 1x240 soft loop - Ryzen 1700X - Corsair Vengeance RGB 2x16GB - Plextor 512 NVMe + 2TB SU800 - EVGA GTX1080ti - LianLi PC11 Dynamic
https://linustechtips.com/topic/891043-dual-cameras/#findComment-10988360
4 minutes ago, xwrench3 said:
why do some cell phones have dual rear mounted cameras? is one for low light operation? or is it to capture a sharper image that otherwise possible?
in the case of the iphone, its designed that way to create a software-biased DOF sensation. (blur the background)
https://linustechtips.com/topic/891043-dual-cameras/#findComment-10988365
5 hours ago, xwrench3 said:
how do i find out? i am looking at a Motorola G5 Plus.
uhh, the G5 Plus only has one rear camera...
System specs:
https://linustechtips.com/topic/891043-dual-cameras/#findComment-10989677
The dual cameras have differing properties such as aperture so that you can take two different looking pics at the same time.  This allows the phone to combine the images with software to create depth of field effects like bokeh.  Dual cameras are in many ways "gimmicky" and not at all a necessity, but its still a nice feature to have.  To be honest though, I don't find the bokeh effects of my Note 8 to be all that superior to the shots my S7E could take.
Intel Core i7 4930K @ 4.7GHz | Asus Rampage IV Extreme | 2 x EVGA GTX Titan SC (1254MHz) | 16GB Patriot Viper Extreme DDR3 2133MHz (4 x 4GB) | Corsair AX1200 | Silverstone Temjin TJ11 | Corsair Force 3 240GB (System) | 2 x Intel 320 160GB SSD (Dedicated Gaming Drives) | Hitachi Deskstar 1TB (Data) | MS Windows 10 Pro | EK Supreme HF/FC-Titan/Rampage IV Extreme blocks | Hardware Labs GTX 560/240 rads | Alphacool VPP-655 D5 pump | Bitspower mod kit/pump top/fittings/120mm res
https://linustechtips.com/topic/891043-dual-cameras/#findComment-10999016
You could just read a review. They're usually pretty in depth.
Quote
You can simply take depth of field photos with the Moto G5S Plus. This is where the background is blurred for an arty effect, emulating the look of a wide-aperture DSLR lens.
It’s not as good as the Huawei or Apple versions of this idea, though. It can’t deal with complicated subjects well and there’s often ‘outlining’ of even simple ones. However, it’s still worth using and can produce some good results.
http://www.techradar.com/reviews/moto-g5s-plus/3#article-body
On 1/31/2018 at 4:44 AM, xwrench3 said:
oops. that's what happens when i look at to many things at the same time. the special edition has dual rear cameras.  which is the one i was looking at.
It's not a special edition, it's just an updated version. You're looking at the G5s Plus.
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/891043-dual-cameras/#findComment-11001036
