Need help picking a cooler
Go to solution Solved by LogicalDrm,
2 hours ago, Varun Kamath said:
1. https://www.vedantcomputers.com/products/cpu-cooler
2. https://www.mdcomputers.in/cooling-system
3. https://www.primeabgb.com/buy-online-price-india/cpu-cooler/
4. https://www.theitdepot.com/products-Liquid+Coolers_C10SU21.html
These are the major non-Amazon retailers with online stores. You will get an idea as to what is readily available here if you browse through their catalog. Sorry for the trouble :S
Seeing the options, best would be to buy 212 and add RGB fan. Best alternative which is probably close to CM is https://www.mdcomputers.in/cooling-system/jonsbo-cr-201-black-rgb.html
Bit cheaper, but CM is overpriced in US too. With Corsair cheapest AIO worth anything is H80i. You could go with H60 if you don't mind noise and lack of performance compared to air coolers at the same price range.
Hi everyone!
I'm looking to swap out my stock AMD wraith spire cooler with an aftermarket cooler. I've shortlisted two, the Cooler Master MasterAir MA610P and the Cooler Master MasterLiquid ML120L RGB. I am curious about overclocking (I've never attempted it before) and I know that if I overclock, I'll have to deal with increased temperatures. Could someone please help me make a decision on which cooler to buy? And yes, I am sort of doing a Brand themed build with cooler master (which is also the most easily available brand in my country) so suggestions within the cooler master catalog would be preferable.
My rig has
Proccessor: AMD R5 1600
Mobo: Asus Prime B350M-A
RAM: Crucial 8GB 2400 Mhz
Thanks in Advance xD
My Rig:
AMD R5 1600; Asus Prime B350M-A, 2x8GB Corsair Vengance LPX DDR4 2400Mhz RAM, Zotac Geforce GTX 1060 6G, Cooler Master Masterwatt Lite 500W PSU, Samsung 850 EVO 250GB Sata SSD, WD Blue 1TB (steam library), WD Blue 4TB (Miscellaneous Storage), 2xCooler Master Air Balance RGB case fans, 1 NZXT Hue+ for case Lighting, all within a Cooler Master Masterbox 5 White Edition Chassis.
https://linustechtips.com/topic/890931-need-help-picking-a-cooler/
Neither. Both are junk for the price. If you really want RGB, get another cooler and put a RGB fan onto it.
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
8 minutes ago, Varun Kamath said:
MA610P
Meh
https://www.kitguru.net/components/cooling/dominic-moass/cooler-master-masterair-ma610p-rgb-air-cooler-review/5/
seems to be rather leaky.  I recommend getting an H7 (quad lumi if you need rgb) or dark rock pro 4 when it comes out
Want to custom loop?  Ask me more if you are curious
3 hours ago, Damascus said:
Or a quad lumi
Cryorig and Dark Rock products aren't available and they are extremely expensive due to customs and local taxes. Any recommendations from corsair?
My Rig:
Nope. Link to store you will be using?
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
Amazon India. Or a bunch of local retailers. India isn't really a big market for PC hardware.
My Rig:
My Rig:
Thanks!
My Rig:
Guest
