Home WiFi Help
Go to solution Solved by Saucetradamus,
Gotcha!! Perfect well thanks for all the help everyone!!!
Look for advice on how to handle this:
99% of the internet used in my house is WiFi. The house is a little older with no ethernet ports running through it, so im limited to the ports directly at my modem. I have fairly fast internet (150 mbps down/ 20mbps up) however, this is mostly limited to the 5ghz band, and most of the locations around the house that require faster internet (such as my gaming pc) are only able to get on the slower 2.5ghz band. I've tried using extenders, but haven't gotten any satisfaction from them. What can I do? Is there anything I can do?
-Thanks
https://linustechtips.com/topic/890111-home-wifi-help/
5 minutes ago, Pangea2017 said:
They are just a repeater a bit different and should work as fine as good "normal" repeater.
If you want full 150 mbit wifi is not ideal for distance.+
Is this possible?
I rent.....So drilling holes and running cables everywhere isn't an option unfortunately :(
https://linustechtips.com/topic/890111-home-wifi-help/#findComment-10979310
So the responses you have gotten so far are not "real" solutions.
If you don't have the money for something like what I'm going to suggest. A couple good extenders can also help.
First a couple of questions.
1. Where in your house is your router and how close to the middle is that?
2. What is your budget? This will determine a lot about what solution is best.
3.How big is your house?
4.What are the walls made of?
If you tell me that my forum post is in the wrong location............ I'll hunt you down and....
https://linustechtips.com/topic/890111-home-wifi-help/#findComment-10979335
Wait can you not run a flat Ethernet cable around? Because if you just want to get it to your PC then you could run it under some carpets if it ruins how you want the house to look. However if it is cost then maybe you could consider moving your wifi router to a more central place
Maybe something's cool down here?
System specs are in profile
Just an average guy looking around the forums for something intresting...
Enjoy your memes. ^_^
https://linustechtips.com/topic/890111-home-wifi-help/#findComment-10979361
Also you could try the power line adapters and if you can get a good connection between them then you can get good speeds
https://linustechtips.com/topic/890111-home-wifi-help/#findComment-10979367
and yes i can run a cable 30 feet across my house to my pc, but the wife wouldnt really like it that much. and i cant move the modem, as it only has one point of connection to the internet.
https://linustechtips.com/topic/890111-home-wifi-help/#findComment-10979380
If you do go for powerline I would recommend trying to get it on the same floor since when I tried powerline it had massive speed decrease and unreliability from having it on two different floors so for example running a cable up the stairs if you can run It hidden
https://linustechtips.com/topic/890111-home-wifi-help/#findComment-10979394
unfortunately running cables (even hiding them as best as possible) isn't really and option for me. Strictly looking for a way to get the maximum range and strength out of what I have. I would love to get access to the 5 ghz band, but even with using extenders in the past, the 5ghz band was still choppy. If anyone has a recommendations for a good extender or something similar that would be great. Also where would be the best location to set it up? Modem is on first floor. PC is on the second floor
https://linustechtips.com/topic/890111-home-wifi-help/#findComment-10979403
The only solution i can see here is to run ethernet to where you want signal and install an AP. Barring that, Powerline adapters (which are not repleaters by any stretch of the imagination) would be the easiest solution if chasing a wire behind a wall isn't exactly your idea of fun.
[FS][US] Corsair H115i 280mm AIO-AMD $60+shipping
System specs:
Asus Prime X370 Pro - Custom EKWB CPU/GPU 2x360 1x240 soft loop - Ryzen 1700X - Corsair Vengeance RGB 2x16GB - Plextor 512 NVMe + 2TB SU800 - EVGA GTX1080ti - LianLi PC11 Dynamic
https://linustechtips.com/topic/890111-home-wifi-help/#findComment-10979408
I would probably order 2 of these https://www.amazon.ca/Ubiquiti-Unifi-Ap-AC-Lite-UAPACLITEUS/dp/B015PR20GY/ref=sr_1_1?ie=UTF8&qid=1516993754&sr=8-1&keywords=ubiquiti+access+point
And a cable like this https://www.amazon.ca/Fosmon-Network-Ethernet-Router-Printer/dp/B00K3202Y4/ref=sr_1_4?ie=UTF8&qid=1516993954&sr=8-4&keywords=cat+6+cable+100ft
Put each one in the most populated areas of your house. But make sure one is upstairs and one is down.
Then plug them into your router. You'll want to disable the wireless antennas on your router by logging into it. They are POE APs so use the included POE injector and you only have to have one wire running to each one.
Edit:
Just saw that you don't want to run cables. But if you use small panduit that can be attached to your wall and paint it the same color it would look pretty good.
https://linustechtips.com/topic/890111-home-wifi-help/#findComment-10979410
http://www.tp-link.com/us/products/details/cat-5509_TL-PA8010-KIT.html + a Managed Wirelss AP of your choice (I'm a big fan of Ubiquiti)
or
http://www.tp-link.com/us/products/details/cat-5509_TL-WPA8630-KIT.html <- straight up gets you wifi where you need it.
System specs:
https://linustechtips.com/topic/890111-home-wifi-help/#findComment-10979412
okay i think this is more on the track that im looking for thanks!. But just to clarify both @XzunderX & @knightslugger.  Will any cable(s) have to be ran from my modem (which is on the first floor of my house), anywhere else (ex: to the ubiquiti AP's or powerline adaptors?
https://linustechtips.com/topic/890111-home-wifi-help/#findComment-10979426
https://www.amazon.com/RT-AC3200-Tri-Band-Wireless-Gigabit-AiProtection/dp/B00XJKH67I/ref=sr_1_13?s=pc&ie=UTF8&qid=1516994286&sr=1-13&refinements=p_89%3AAsus
And
https://www.amazon.com/Rosewill-RNX-AC1900PCE-802-11AC-Express-Wireless/dp/B0159222VS/ref=sr_1_3?ie=UTF8&qid=1516994365&sr=8-3&keywords=pci+express+wireless+ac
These 2 items will allow you to get much closer to the speed you pay for. I had a similar problem in my 5000 sqft house and this router was the solution. The PCI-E adapter is so you can take advantage of the AC standard.
What type of router do you currently have? Are you using the modem/router combo your ISP provides?
https://linustechtips.com/topic/890111-home-wifi-help/#findComment-10979431
the only cable you will need is the one from the gateway 3-in-1 (router) to the first powerline adapter which should be right next to the gateway. The other one will be located on a wall power socket where you want wifi signal.
The Ubiquiti AP is a hardline option and would require you to run Cat5e across your house... which is not what you want. The Powerline adapters i linked would be your best bet. They might have to jump breakers so don't expect gigabit speeds out of this setup, but you should get 150Mbps no problem.
System specs:
https://linustechtips.com/topic/890111-home-wifi-help/#findComment-10979437
well one had built-in wifi (the $100+ one) whereas the other was just a ethernet to ethernet pair (which you'd connect to an AP or a computer, or TV, or whatever had an ethernet plug).
System specs:
https://linustechtips.com/topic/890111-home-wifi-help/#findComment-10979456
Yeah also for troubleshooting the powerline adapters after you have them I would try plugging them in to the same Floor so you can test if they aren't dead.
https://linustechtips.com/topic/890111-home-wifi-help/#findComment-10979486
