I just upgraded my cpu from an pentium g4560 to a i5 6500. The problem is my pc powers on stays on but refuses to display anything. I put the old cpu in and it worked fine, and i also reset the bios... my specs are mobo - b250m pro-vd gpu - gtx 1060 3gb ram - 8gb and a 450 watt psu
https://linustechtips.com/topic/889873-help-pc-wont-display/
28 minutes ago, Cupar19 said:
Does the motherboard support the CPU?
If so does it require a bios update?
Have you plugged your cable into the graphics card and not the motherboard?
Have you plugged your cable into the motherboard in case the graphics card is not detected?
Yep, everything is compatible and everything worked with the old cpu.
https://linustechtips.com/topic/889873-help-pc-wont-display/#findComment-10976771
Bent pins? I just had that problem fixed it with a razer blade.
First watercooled System
Build Name: White Knight
OS: Windows 11 Pro 64-bit
Monitor: Alienware AW3423DWF 1800R Curved Ultrawide 3440x1440 QD-OLED 157hz 10 bit 0.1ms
Chassis: Lian Li 011 Dynamic EVO w/ 2x120mm Corsair QL RGB Fans on the bottom 1x120mm on back exhaust
Top Rad & Fans:  Corsair 54mm 360mm w/ 3x120mm Corsair ML Pro RGB Fans
Side Rad & Fans: Corsair 30mm 360mm w/ 3x120mm Corsair QL RGB Fans
Motherboard: Asrock X670E Steel Legend
CPU: AMD Ryzen 7 7800X3D w/ Corsair XC7 RGB Pro w/ Kyrosheet
Memory/RAM: Corsair Dominator RGB DDR5 2x16GB 32GB 6000Mhz
GPU: Asus GeForce RTX 4080 TUF w/ EK-Quantum Vector2 Nickel/Plexi & Backplate
Pump/Reservoir: Corsair XD5 RGB
Coolant: Corsair Clear
PSU: Lian Li Edge 1000W
Boot/OS SSD: Samsung 970 EVO Plus 500GB NVMe
WZ/2042 SSD: Samsung 850 EVO 250GB
Game SSD: Samsung 980 Pro 1TB
Performance/Editing HDD: Western Digital Black 1TB
Storage HDD: Western Digital Blue 1TB
Mouse: Razer Lancehead Tournament Edition/Razer Mamba
Mouse Mat: Corsair MM700 RGB
Keyboard: Razer Ornata Chroma
Microphone: Beacn Mic
Headset: Razer Blackshark v2 Pro
Eyewear/Glasses: Gunnar Optiks Razer FPS/Gamer Advantage Liquid
Camera: Razer Kiyo Pro/OBSBOT Meet SE
https://linustechtips.com/topic/889873-help-pc-wont-display/#findComment-10976830
Have you tried updating bios or clear Cmos?
https://linustechtips.com/topic/889873-help-pc-wont-display/#findComment-10976849
When you clear the CMOS, it resets the BIOS to default, which includes setting the default video output to the iGPU, not your discrete GPU. You'll have to fix that later in the BIOS. When you clear the CMOS, it's not setting it back to the old BIOS, it's clearing all user input values from your new BIOS.
So, next steps: Set the primary video output to PCIe1 or whatever slot your gpu is in, then restart until you get display off it takes a few tries sometimes.
If you done that as well, I'll have to do more research. xD
https://linustechtips.com/topic/889873-help-pc-wont-display/#findComment-10976876
Still nothing, maybe a bad cpu? Can a pc still turn on with a bad cpu? Also my motherboard has a diagnostic led but it stays off which is good but i wonder if the motherboard cant detect the bad cpu.
https://linustechtips.com/topic/889873-help-pc-wont-display/#findComment-10977043
A bad cpu is a bit rare, but no it won't post if the cpu is bad. Is it new or used?
https://linustechtips.com/topic/889873-help-pc-wont-display/#findComment-10977104
Used from an actual company, e-cyclepro, they provide refunds but if its not the cpus fault for the problems i dont want to run into this problem again.
https://linustechtips.com/topic/889873-help-pc-wont-display/#findComment-10977111
Does this company verify it works?
https://linustechtips.com/topic/889873-help-pc-wont-display/#findComment-10977124
