Sup guys, I am planning to build my own gaming pc with some media related like OBS, Photshop and Lightroom. I am not familiar with the magic numbers and letters on pc parts so I spend time on researching, what they're for, which is the best, etc. And I came up with this build.
Im not an overclocker guy and I just play some not that powerful games like dota2, pubg, cs:go, etc. Im not planning to play some AAA titles games like Gta V, battlefield, tomb raider, etc (remove the gamer in me if you want). I just want to play games at their highest resolution with ease and comfort.
And Im trying to budget some parts here so I didnt go for what is the latest. I picked parts that will do the work but still gives a good performance.
And I need help if these parts will fit on my chosen case because its a compact thingy so I need to double check those sizes and spacing.
Feel free to say or comment anything. I need some opinions here.
CPU- i7-7700   *i7-7500 or i7-7600 if compatible*
MoBo- Asus Strix H270f
CPU Cooler- Nzxt x52 rev2
GPU- Asus GeForce 1060 6GB
Ram- Crucial Ballistix sport LT 8gb (1x8gb) DDR4-2666
Storage- Whatever nomal 250gb ssd and 1tb hhd
PSU- Corsair RMx 550w 80+ gold fully modular. (Should i go low?)
Case- Fractual design Meshify C
https://linustechtips.com/topic/889860-i-need-help-on-specs/
spec of monitor?
Getting 7th gen is a bad idea because it's an old platform. 8th gen or Ryzen is better.
Water cooler but not overclocking? What a waste of money.
Desktop benching:
https://linustechtips.com/topic/889860-i-need-help-on-specs/#findComment-10976517
9 hours ago, Jurrunio said:
spec of monitor?
Noted on the cpu.
So watercooling is nah if not overclocking.
Will it affect the not overclock cpu if I still use it? Coz it looks good tho hehe so Its for the showoff purpose.
I havent chosen a monitor yet.
What about the spacing inside the case with given components, will a 240mm front rad plus 298mm gpu would fit?
https://linustechtips.com/topic/889860-i-need-help-on-specs/#findComment-10977784
If you are willing to pay for the looks then I dont have much to say.
It can, someone did just that
https://pcpartpicker.com/b/TfnH99
That said, I myself is against using a premium graphics card for a mid range GPU like a 1060. That said I cant judge when it comes to looks
Desktop benching:
https://linustechtips.com/topic/889860-i-need-help-on-specs/#findComment-10977793
I dont quite get you here. Is graphics card and gpu is different? (Sorry for the innocence) or I just read that wrong?
https://linustechtips.com/topic/889860-i-need-help-on-specs/#findComment-10977892
GPU is the computing core, which means I have a GTX 1070. Graphics card includes the core and the rest, like cooler, fans, power delivery etc, which means I have an Asus GTX 1070 Dual. That easier to understand?
Desktop benching:
https://linustechtips.com/topic/889860-i-need-help-on-specs/#findComment-10977899
