GPU OC settings for mining
Solved by metalnot,
Reading about it's algorithm (i didn't know it so far) - Scrypt-N, it appears to also be dependent to memory so you could try to start "OC" starting from 100% and lower the power limit untill you see a drop in hashrate. Stop there and slowly increse memory clocks (i do it by 100 on the 1080ti) until it doesn't grow anymore. At that point you could try to slowly increase the core clock a little and see if it does any hashrate increase. if it doesn't, either lower it or let it stock. Always check your temps so they don't go high. (keep them under 65C).
