These are my parts .
Please let me know if there is anything out of place or things i can improve on. Don't worry about peripherals.
CPU: AMD - Ryzen 5 1500X 3.5GHz Quad-Core Processor  ($162.79 @ SuperBiiz)
Motherboard: MSI - B350M GAMING PRO Micro ATX AM4 Motherboard  ($70.98 @ Newegg)
Memory: G.Skill - Ripjaws 4 Series 8GB (2 x 4GB) DDR4-3200 Memory  ($108.99 @ Newegg)
Storage: Silicon Power - S60 60GB 2.5" Solid State Drive  ($102.80 @ Amazon)
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($46.55 @ OutletPC)
Video Card: Asus - Radeon RX 470 4GB STRIX Video Card
Case: Cooler Master - MasterBox Lite 3.1 MicroATX Mid Tower Case  ($39.99 @ Amazon)
Power Supply: EVGA - 430W 80+ Certified ATX Power Supply  ($45.89 @ OutletPC)
Total: $577.99
Thanks !
https://linustechtips.com/topic/888902-budget-pc-help/
Just now, A Dedicated Gamer said:
Ryzen 5 1500X
You don't really want the "X" variant as it is just higher clocked and you can OC a normal one to that speed.
For $100 you should be getting a lot more than 60GB. More like 128 - 240GB SSD.
I would get a Ryzen 3 and a better GPU if this is for gaming.
Don't know if this is ok or not. I would ask the PSU tier dudes.
ORANGE SCREEN WINDOWS 10 VALUE OVER TIME - PC VS MAC
i5 7600k @ 5.0 GHz xD
Corsair H60 with Noctua NF-F12 iPPC-3000 PWM
MSI Z270-A Pro Motherboard
EVGA 1050 Ti SC
16 GB Corsair DDR4 @ 2400 MHz
500 GB Sandisk 950 PRO - Windows 10, Elementary OS, Zorin OS
500 GB Sandisk 850 PRO
1 TB WD Blue
Corsair CX750
1 x Corsair AF120 Quiet Red Led
Rosewell Tyrfing Case
EliteBook 8570w
i7 3720QM @ 2.6 GHz
Quadro K1000M
24 GB DDR3 @ 1600 MHz
250 GB SanDisk 850 EVO - Elementary OS, Windows 10, Debian
i5 3470 @ 3.2 GHz
EVGA 750 Ti SC
8 GB DDR3 @ 1333 MHz
240 GB SanDisk - Windows 10, Linux Mint
https://linustechtips.com/topic/888902-budget-pc-help/#findComment-10966964
Can you link the pc partpicker list? Your lucky to find a rx 570. I would also (If you can find it for the cost) get a rx 580 over a 570, or pivot to a 1060 6gb (again if you can find it for the right price.
Also don't buy a 1500x. Either way for the Ryzen + starting in February, or buy the 1600, its totally worth it. I don't think any of the R5 non 1600 are worth it. Either a 1200 or a 1600.
I would rather agree on what we share, than fight on what we don't. - Myself
FULL PC SPECS ON PROFILE https://linustechtips.com/main/profile/454099-thinkfreely/
https://linustechtips.com/topic/888902-budget-pc-help/#findComment-10966965
https://pcpartpicker.com/list/FndDCy
Hey i've seen you on youtube !
In other words i'm a mess when it comes to building pcs!
Thanks for the help ..
https://linustechtips.com/topic/888902-budget-pc-help/#findComment-10966986
try this:
CPU: AMD - Ryzen 5 1600 3.2GHz 6-Core Processor  ($197.68 @ OutletPC)
Motherboard: ASRock - AB350M Pro4 Micro ATX AM4 Motherboard  ($74.49 @ SuperBiiz)
Memory: G.Skill - Aegis 8GB (1 x 8GB) DDR4-3000 Memory  ($95.99 @ Newegg)
Storage: Crucial - MX500 250GB 2.5" Solid State Drive  ($79.89 @ OutletPC)
Power Supply: Corsair - CXM 550W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($39.99 @ Newegg)
Total: $574.58
Generated by PCPartPicker 2018-01-22 20:17 EST-0500
https://linustechtips.com/topic/888902-budget-pc-help/#findComment-10967020
Total: $577.99
Thanks !
samsung 850 evo 250gb ssd' are $99 on sale and they have been going on small sales if you can find them. I would either spend an extra $40 for the 6 core ryzen 5 1600 or save $60 and go with a ryzen 3 1200. And how much is the video card in all of this because the rx 470 is a verrry popular mining card and unless you have a nice friend selling it to you for cheap I can tell you it's gonna be expensive
https://linustechtips.com/topic/888902-budget-pc-help/#findComment-10967023
Just now, herman mcpootis said:
try this:
Total: $574.58
Super funny I mad exactly the same changes. I just left out the GPU (Until in stock for closer to a normal price)
Storage: Samsung - 850 EVO-Series 250GB 2.5" Solid State Drive  ($89.99 @ B&H)
Total: $594.17
Generated by PCPartPicker 2018-01-22 20:18 EST-0500
https://linustechtips.com/topic/888902-budget-pc-help/#findComment-10967027
Ya, no everything needs to be fixed
Where are you even buying the GPU? When were you going to build this? You should 100% wait for the ryzen APUs coming in february, unless you already have the RX 570
https://linustechtips.com/topic/888902-budget-pc-help/#findComment-10967037
This is my first Ryzen build . I always tend to lean towards intel but i want to give Ryzen a shot , I've seen good reviews.
Total: $594.17
Wow much better now. I think i'm going to base my build off these parts. I will obviously wait 3 months or so for GPU prices to go down.
Thanks for the critic guys. Much needed.
https://linustechtips.com/topic/888902-budget-pc-help/#findComment-10967068
Just get an APU build when it launches soon, it gives you basically an R5 1400 + RX 550 for a decent price.
And if you're waiting longer than the Ryzen APUs, Ryzen + is coming with X470 boards, so there's not much reason to plan now.
That case has no airflow, shouldn't buy it. Could drop the SSD and get a better motherboard, just add an SSD later as well when it's prices are down. Or buy a Seagate Firecuda should they go on sale, it's a hybrid drive.
https://linustechtips.com/topic/888902-budget-pc-help/#findComment-10967083
Total: $594.17
the MSI board is much worse than the pro4
https://linustechtips.com/topic/888902-budget-pc-help/#findComment-10967493
54 minutes ago, Dovaogedy said:
Has there been any word on whether the ryzen 2200g/2400g will work on b350 boards?
Course it will, it'll just need a BIOS update, and there should be new/updated boards shipping with updated BIOS
https://linustechtips.com/topic/888902-budget-pc-help/#findComment-10969066
