CoD Ghost is the issue. hint hint
| Case: NZXT Tempest 210 | CPU: Intel Core i5 3570K @ 3.9 Ghz | GPU: ASUS ROG STRIX GTX 1070 | RAM: Crucial Ballistix Tactical 8GB |
| Mouse: Zowie FK1 | Monitor: Acer 21.5' | Keyboard: CoolerMaster Stealth w/ Brown Switches |
#KilledMyWife - #LinusButtPlug - #1080penis
https://linustechtips.com/topic/88885-cod-ghosts-mic-issue/#findComment-1203174
I have never heard anyone talking in Ghosts (PC). I haven't tried voice chat myself so can't help.
Rig: i7 2600K @ 4.2GHz, Larkooler Watercooling System, MSI Z68a-gd80-G3, 8GB G.Skill Sniper 1600MHz CL9, Gigabyte GTX 670 Windforce 3x 2GB OC, Samsung 840 250GB, 1TB WD Caviar Blue, Auzentech X-FI Forte 7.1, XFX PRO650W, Silverstone RV02 Monitors: Asus PB278Q, LG W2243S-PF (Gaming / overclocked to 74Hz) Peripherals: Logitech G9x Laser, QPad MK-50, AudioTechnica ATH AD700
https://linustechtips.com/topic/88885-cod-ghosts-mic-issue/#findComment-1203193
I neither own the game nor the headset.
  • Have you installed all the drivers correctly?
  • Is your Mic set as the default recording device in your windows soundmanager?
  • Is your Mic set as the recording device in CoD?
Frost upon these cigarettes.... lipstick on the window pane...
https://linustechtips.com/topic/88885-cod-ghosts-mic-issue/#findComment-1203246
Anyone else having problems with making their mic work? I have the Tiamat 2.2 and they work fine in skype, but whenever I play Ghosts no one can hear me. Any ideas on what is wrong? I could really use some help.
Control Panel --> Hardware and Sound --> Sound --> Recording --> Right click the mic your using and click properties --> Levels. Then make sure mic is on 100% and boost on 30 dB.
Make sure to lower the boost to 20 dB when on anything else.
https://linustechtips.com/topic/88885-cod-ghosts-mic-issue/#findComment-1203377
