Carbide 330R and V8 GTS V2 cooler
sof006
How compatible are these together? I am checking PC Part Picker website and it seems to suggest they're fine together. How accurate is this website, I want to get a quieter cooler for my PC as my H100i isn't as quiet as i'd like it to be.
System Specs:
CPU: Ryzen 7 5800X
GPU: Radeon RX 7900 XT
RAM: 32GB 3600MHz
HDD: 1TB Sabrent NVMe -  WD 1TB Black - WD 2TB Green -  WD 4TB Blue
MB: Gigabyte  B550 Gaming X- RGB Disabled
PSU: Corsair RM850x 80 Plus Gold
Case: BeQuiet! Silent Base 801 Black
Cooler: Noctua NH-DH15
Doesn't seem like they are compatible. Corsair lists specs of 160mm max cooler height for the case. The cooler appears to be 166mm tall.
Intel Core i7 8700k | be quiet! Dark Rock 4 | Fatal1ty Z370 Gaming-ITX/ac | 32 GB G.Skill TridentZ | 256 GB Intel® SSD 600p Series | ZOTAC GeForce® GTX 1080 Ti Mini | Fractal Design Node 304 | Cooler Master V750 | Asus MG279Q | Asus VC279 | Logitech G710+ | Corsair M65 Pro RGB
Hmm how about the Dark Rock 3 Quiet
https://www.scan.co.uk/products/be-quiet!-dark-rock-3-single-tower-cpu-cooler-6-heatpipes-1x-135mm-pwm-fan-190w-tdp-for-intel-amd-cp
System Specs:
CPU: Ryzen 7 5800X
RAM: 32GB 3600MHz
2 minutes ago, sof006 said:
The tech specs give it a 163mm height. Still too tall. Just look for cooler height or dimensions in the technical specs of any cooler. I look up the product on the manufacturer's website, it's where the most accurate info on size will be.
Hmm good shout, i'll take a look at the 330R on Corsairs website see what they suggest.
System Specs:
CPU: Ryzen 7 5800X
RAM: 32GB 3600MHz
