Download the Chrome installer on another machine and move it to this one via flash drive. Then run it from there without having to go through Edge.
https://linustechtips.com/topic/888106-edge-not-downloading/#findComment-10958670
22 minutes ago, ChrisMcNair said:
the problem is I don't have a flash drive and my family don't either. I also cant buy one as I need to solve this problem by tomorrow.
You may follow the steps provided below and check if it helps to resolve the issue.
  1. Open Microsoft EDGE.
  2. After that click on (…)  option which is visible at top right side of the browser and you will see “Settings” option.
  3. Under Settings scroll down and you will see a button “Choose what to clear” under “Clear browsing data” option.
  4. Once you click on this option you will see list of feature, Select Cached data and file.
  5. Here you need to check the option you want to clear and click “Clear” button.
https://linustechtips.com/topic/888106-edge-not-downloading/#findComment-10958820
Doesn't work but thanks anyway
https://linustechtips.com/topic/888106-edge-not-downloading/#findComment-10958891
