Here are the facts as I understand them. My PC blue screens with memory_management and attempted_to_write_to_read_only_memory. I've run Windows memory diagnostic with 0 errors. Same with Memtest86 v5. Premiere Pro no longer renders my videos without crashing and AME renders them with an exponential curve of how long it takes to complete. Almost like a car going through gears and accelerating. I am completely lost for words. I almost missed upload schedule today and I cannot have that happen again.
Please help
16GB RipJawz 5 2400
R7 1700
MSI B350M Mortar
Windows 10 Pro 64 (probably should install 8.1 again but hey ho)
No one likes fanboys.
https://linustechtips.com/topic/887939-huge-problem-pls-help/
heres a few things you can try:
try without overclock on memory
take out as many sticks of ram as you can with leaving only one stick in
than swap out the sticks, testing all the memory modules to find the faulty module
if that doesnt work choose one stick and test it in every ram slot.
than repeat the process with a different stick if no results were found
Main Rig | Personal Build | Windows 10 | R7 2700x 3.7~4.3ghz | ASUS ROG Strix B450-I | 16gb DDR4 3200mhz | GTX 1080 FE | Coolermaster Elite 130 | Corsair H60 | WD Blue SN500 500GB NVMe SSD + 1tb WD Green HDD + 1tb WD Blue HDD
Laptop | HP m6-w102dx | Windows 10 | i7-5500u 2.4~3.0ghz | 8gb DDR3L | GT 930m 2gb| 120gb Sandisk SSD
Phone | Pixel 3 | Verizon | 64gb
https://linustechtips.com/topic/887939-huge-problem-pls-help/#findComment-10957268
