Hello, I need assistance pronto as this is my main rig, I appear to have an issue that needs to be fixed, although i do have an extra graphics card on me, it will not fit in the case as this is an asus rog pc. I need solutions asap as this is my primary rig.
Specs:
Windows 10
GTX 770
i7 4790
https://linustechtips.com/topic/887529-help-asap/
First of all your Picture is absolutely not helpful at all. If you have a problem with your Motherboard or GPU or your Case I strongly suggest to take a Picture of your problem and not of your desk.
So, as I read the post I guess the error is that your Graphic Card does not fit in your case and now there is no GPU connected at all?
If this is the Case I suggest buying a bigger Case which fit´s your Graphic Card.
https://linustechtips.com/topic/887529-help-asap/#findComment-10954080
