Monitor arm for an ultrawide
1 minute ago, DildorTheDecent said:Sounds like a good idea. Might help with clearance since most the dual mount ones look to be paired together, which I imagine would make stacking difficult. Two single mounts allows some freedom between them.
Just need the right pole + some of those spring arm thingies. Although I guess just that to start with would be alright. I can scour eBay for a bit to see what it has.
It looks like the wall mount arms are the same arms as the ones on the dual arm mount you linked. They can be removed from the mount and there's bolts on the side that can be tightened or loosened to make it easier or harder to swing around. I recently took mine apart because I added a new monitor and needed the Duronic mount in a different place to make it work. It seems like the mounting is the same across all of them, so they should fit on the poles.
The only thing I'm not sure on is how to stop them from sliding down the pole. It looks like most have little stoppers to prevent that, but I don't know if the poles or arms come with them.
Based on the images from the DM45/DM55 compatible poles, it actually looks like the arms just clamp onto the pole rather than having any stopper. In that case, all you need is one of the poles and two of the wall mount arms and it should work fine. If you go with one of the extra long arms, they have a three clamp mechanism, which will provide a bit more stability, but they are 80 and 100cm long poles.
Probably the cheapest way to do what you want is to buy a DM55 arm and pole mount and then buy another DM55 arm. It's about £20 cheaper than buying the pole and two arms.
So this and this. It's the same price to go for the ones with the extension arms, which add some extra adjustability, so that's what I'd go for.
