From network security point of view, turn off WPS completely and connect by the usual key method. Way more secure, WPS has a lot of loopholes.
HAL9000: AMD Ryzen 9 3900x | Noctua NH-D15 chromax.black | 32 GB Corsair Vengeance LPX DDR4 3200 MHz | Asus X570 Prime Pro | ASUS TUF 3080 Ti | 1 TB Samsung 970 Evo Plus + 1 TB Crucial MX500 + 6 TB WD RED | Corsair HX1000 | be quiet Pure Base 500DX | LG 34UM95 34" 3440x1440
Hydrogen server: Intel i3-10100 | Cryorig M9i | 64 GB Crucial Ballistix 3200MHz DDR4 | Gigabyte B560M-DS3H | 33 TB of storage | Fractal Design Define R5 | unRAID 6.9.2
Carbon server: Fujitsu PRIMERGY RX100 S7p | Xeon E3-1230 v2 | 16 GB DDR3 ECC | 60 GB Corsair SSD & 250 GB Samsung 850 Pro | Intel i340-T4 | ESXi 6.5.1
Big Mac cluster: 2x Raspberry Pi 2 Model B | 1x Raspberry Pi 3 Model B | 2x Raspberry Pi 3 Model B+
https://linustechtips.com/topic/886348-iphone-wps-problem/#findComment-10941527
48 minutes ago, Balrog0fMorgoth said:
Update the router software, also have you tried "forgetting" the network on your iPhone? Short of that the tried and true off/and then back on for both the router and your iphone.
yes i have done that also i tryed setting up a statik dns
https://linustechtips.com/topic/886348-iphone-wps-problem/#findComment-10943005
