Ethernet From Motherboard
PCGal
I know this is probably a stupid question to ask, but it's worth a shot. Is it possible to output Ethernet through the port on my motherboard? I use a wifi card and I need more internet in my room and have no money right now to do it with. If this is not possible I understand, but I think its worth a shot.
Thanks in advanced.
2 hours ago, Oshino Shinobu said:
You should be able to set it up as a network bridge. Here's a guide on how to do it:
https://www.windowscentral.com/how-set-and-manage-network-bridge-connection-windows-10
sorry it took so long to reply, but I was troubleshooting. I only have my single wifi adapter and no matter what I did, I had no way of getting it working
When you say you use a wifi card do you mean you get wifi at your pc from a wifi router or are you using a 3G/4G or similar dongle?
If you're interested in a product please download and read the manual first.
Don't forget to tag or quote in your reply if you want me to know you've answered or have another question.
