Ok so this is my first build and I'm having a bit of trouble with the drivers. I have a gigabyte ga ab350 gaming 3, Ryzen 5 1600, windows 10. I'm downloading all the drivers from the manufactures websites. Now when I go to install them from the file I downloaded it needs to restart. I installed the Audio driver that seems to have gone good. I installed the Graphics card driver that also seemed to go good. I'm now on the chipset driver. I think I installed it I'm not completely sure however. Whenever I install the drivers I go into the device manager and see if the drivers were installed. For the audio driver I just went into device manager, pressed on sound video and game controls, where it shows the driver I installed. Their its says driver added-then the time it was installed. Its the same for the graphics card and the audio but when I installed the chipset driver I went into processors and none of them had the driver I installed onto them(there were like 20 dif ryzen 5's). I'm pretty sure the chipset driver is for the processor so if I'm right they should e appearing right their right? Also on to he gigabyte web page it says that along with the chipset driver the usb driver is installed too. I went into Universal serial bus controls which is on device manager at the bottom and by the looks of it it didn't look like their were any changes their either. Can someone please help me I'm pretty frustrated about the whole thing.
https://linustechtips.com/topic/885646-drivers-help-please/
Only drivers you have to worry about on Win10 is the display drivers, which you installed.
Want to know which mobo to get?
Choose whatever you need. Any more, you're wasting your money. Any less, and you don't get the features you need.
Only you know what you need to do with your computer, so nobody's really qualified to answer this question except for you.
chEcK iNsidE sPoilEr fOr a tREat!
https://linustechtips.com/topic/885646-drivers-help-please/#findComment-10935449
