So I built my first pc about 2 years ago and I've been out of the loop of computers for a while. I'm looking to upgrade my current pc to be up to spec with the current market today and be more relevant. I'm just looking for recommendations and don't have a specific budget but just want to improve on the overall performance.
My current build:
i5 4690k
MSI Gtx 970
Msi Z97 Gaming 5
HyperX DDR3 8GB 1866 ram
Corsair RM 650 PSU
The first thing I should do really is to buy an AIO cpu cooler since I can't be relying on a stock cooler so would like some recommendations on that!
Thanks!
https://linustechtips.com/topic/885413-upgrading-current-build/
Why are you upgrading, though? Those specs seem fine. Do you just want the latest and greatest?
Ryzen 5 1600 @ 3.9 Ghz  | Gigabyte AB350M Gaming 3 |  PaliT GTX 1050Ti  |  8gb Kingston HyperX Fury @ 2933 Mhz  |  Corsair CX550m  |  1 TB WD Blue HDD
Inside some old case I found lying around.
https://linustechtips.com/topic/885413-upgrading-current-build/#findComment-10933223
It just seems to be slowing down and I feel like its a pretty old computer, maybe I should try overclocking but I have yet to delve into the world of overclocking. I was thinking of buying a used 970 and configure it in SLI but I'm not sure if its worth it and should just buy a 1060/1070?
https://linustechtips.com/topic/885413-upgrading-current-build/#findComment-10933240
Are you using an HDD or SSD for your OS? If it's the former, you can probably replace just that. I wouldn't recommend SLi as a single 1060 would probably perform around the same as that and the 1070 would beat it no questions.
https://linustechtips.com/topic/885413-upgrading-current-build/#findComment-10933259
I'm using a crappy 120gb ssd for my OS but I am thinking of getting a 256gb/500gb ssd, or shall I just invest into another 1tb hdd? Just wondering how far my 970 will go in terms of games, since most games nowadays are more demanding
https://linustechtips.com/topic/885413-upgrading-current-build/#findComment-10933265
Are you experiencing any issues with your games?
How is your system slowing down?
https://linustechtips.com/topic/885413-upgrading-current-build/#findComment-10935765
