Urgent Help Crashed
Go to solution Solved by Ace McPlane,
17 minutes ago, xD Power Hole Stick said:
Ok, then what to do in DDU?
i have started downloading drivers from nvidia site
Here's a guide on how to use DDU.
(Run it as administrator and do it in safe mode)
http://windowsreport.com/display-driver-uninstaller-windows-10/
Also, have you updated any motherboard drivers recently?
Gigabyte motherboards can be confusing for this.
There are multiple revisions of the same board with each one.
You have to physically look on your motherboard to find out what revision you have.
If you install a driver that's for a different board, you're going to have a bad time.
I highlighted where the revision number for your board will be in red.
Just expand the photo to see it.
5a58d9afad210_gigabytehasstupidmodelnumbers.thumb.jpg.05d2b3435fa034b95fc59113b578d769.jpg
A hard restart doesn't solve the problem? Driver corruption? Memory failure?
[FS][US] Corsair H115i 280mm AIO-AMD $60+shipping
System specs:
Asus Prime X370 Pro - Custom EKWB CPU/GPU 2x360 1x240 soft loop - Ryzen 1700X - Corsair Vengeance RGB 2x16GB - Plextor 512 NVMe + 2TB SU800 - EVGA GTX1080ti - LianLi PC11 Dynamic
https://linustechtips.com/topic/885039-urgent-help-crashed/#findComment-10930023
Just now, headhunter7987 said:
After you test the onboard graphics,  try putting your GPU in a different PCIE slot to test it.
And then maybe another power cable/power port on the PSU if you have a modular, to it if it still does not work in another PCIE.
https://linustechtips.com/topic/885039-urgent-help-crashed/#findComment-10930047
3 minutes ago, LorLor said:
Okay, try with on-board first, then let us know if that works okay, then we can go from there.
That's not gonna work. FX series CPUs don't have integrated graphics.
https://linustechtips.com/topic/885039-urgent-help-crashed/#findComment-10930069
Just now, xD Power Hole Stick said:
i have 4300
Hmm. What have you tested already?
https://linustechtips.com/topic/885039-urgent-help-crashed/#findComment-10930080
1 minute ago, xD Power Hole Stick said:
reseating gpu and ram using eraser to remove carbon tighting the gpu even tighter than before
Try at least turning it on without the GPU installed and see if POSTs and check the POST codes in your manual. That should give you a pretty good idea of what failed, try it with the GPU installed as well to rule that out.
https://linustechtips.com/topic/885039-urgent-help-crashed/#findComment-10930095
i know it post without gpu
https://linustechtips.com/topic/885039-urgent-help-crashed/#findComment-10930101
OK, that's a start. What happens if you try booting it with the GPU installed?
https://linustechtips.com/topic/885039-urgent-help-crashed/#findComment-10930109
it boots normal and works fine like here i am using to get help
but if i play crew this blue thing come after 15-20 mins in game
download the latest driver, download and run DDU to uninstall the old one, and then reinstall using the new driver.
System specs:
https://linustechtips.com/topic/885039-urgent-help-crashed/#findComment-10930149
