..um..no, you're supposed to push it all the way in.
Ryzen 5 1600 @ 3.9 Ghz  | Gigabyte AB350M Gaming 3 |  PaliT GTX 1050Ti  |  8gb Kingston HyperX Fury @ 2933 Mhz  |  Corsair CX550m  |  1 TB WD Blue HDD
Inside some old case I found lying around.
https://linustechtips.com/topic/884978-help/#findComment-10929524
....you push it.
https://linustechtips.com/topic/884978-help/#findComment-10929530
Just now, lachlan02 said:
How do I push it in
lol, give it a little just push it until you hear a click, but first take the graphics card out and push it in slot again.
PC Specs : i7 7700k, 24 GB @ 2666 MHz, ASUS Strix GTX 970, ASUS Z170-K, 960 EVO 250 GB, 850 EVO 250 GB, 2x 2 TB WD Purple RAID 0, Green 1 TB
https://linustechtips.com/topic/884978-help/#findComment-10929532
Don't be afraid to use a little force.
https://linustechtips.com/topic/884978-help/#findComment-10929538
