how do you know it's 48%? That's what afterburner reports and it just pops back up when you lower it?
Desktop benching:
https://linustechtips.com/topic/884951-gpu-fans-problem/#findComment-10929339
Maybe the bios was flashed. Have you tried flashing the original bios back on to the card?
If you're interested in a product please download and read the manual first.
Don't forget to tag or quote in your reply if you want me to know you've answered or have another question.
https://linustechtips.com/topic/884951-gpu-fans-problem/#findComment-10929541
Check if there's a BIOS update utility for the card in its website. Otherwise you might need to flash the BIOS yourself.
Desktop benching:
https://linustechtips.com/topic/884951-gpu-fans-problem/#findComment-10929585
Try another program. Which card is it exactly?
https://linustechtips.com/topic/884951-gpu-fans-problem/#findComment-10929902
So is it running at a certain temp? May be a safety issue as it wants to stay at a certain temp. Really depends on the bios setup and assuming the wires are still intact on the fan assembly.
https://linustechtips.com/topic/884951-gpu-fans-problem/#findComment-10930271
