I'm looking to upgrade my pc that I bought a while ago. I game on it majority of the time. I play league of legends, pubg, overwatch, and plan on picking up playing Monster Hunter: World and DB FighterZ. I also hope to stream a little. My upgrade budget is $500 - $600 USD. Any help is appreciated! <3
Current Specs:
CPU: AMD Fx- 6300
Mobo: MSI 970A - G43
RAM: 2x 8gb Ballistix DDR3
GPU: MSI Gtx 960
HDD: 1TB
PSU: Corsair RM 550
https://linustechtips.com/topic/884933-help-upgrade-my-pc/
a 1600, B350 board, 8gb of ram and a gtx 1060 if it fits into the budget.
https://linustechtips.com/topic/884933-help-upgrade-my-pc/#findComment-10929123
I'm just going to assume you're in the US:
CPU: Intel - Core i5-8600K 3.6GHz 6-Core Processor  ($259.99 @ Amazon)
CPU Cooler: CRYORIG - H7 49.0 CFM CPU Cooler  ($29.90 @ Newegg Marketplace)
Motherboard: MSI - Z370-A PRO ATX LGA1151 Motherboard  ($101.98 @ Newegg)
Memory: Crucial - Ballistix Sport LT 8GB (1 x 8GB) DDR4-2400 Memory  ($87.89 @ OutletPC)
Storage: Silicon Power - Slim S55 240GB 2.5" Solid State Drive  ($67.99 @ Amazon)
Total: $547.75
Generated by PCPartPicker 2018-01-12 02:24 EST-0500
Make sure to quote or tag me (@JoostinOnline) or I won't see your response!
PSU Tier List  |  The Real Reason Delidding Improves Temperatures"2K" does not mean 2560×1440
https://linustechtips.com/topic/884933-help-upgrade-my-pc/#findComment-10929129
Total: $547.75
So no GPU upgrade?
https://linustechtips.com/topic/884933-help-upgrade-my-pc/#findComment-10929132
1 minute ago, ConfessionBear said:
So no GPU upgrade?
No.  Your CPU is what is really slowing you down.  A 960 isn't too bad.
I prioritized gaming over streaming in the Intel build.  If you'd prefer to focus on streaming (it won't hurt your gaming performance that much), here's a Ryzen build:
CPU: AMD - Ryzen 7 1700 3.0GHz 8-Core Processor  ($288.27 @ OutletPC)
Motherboard: ASRock - AB350 Pro4 ATX AM4 Motherboard  ($73.98 @ Newegg)
Memory: G.Skill - Ripjaws V Series 8GB (2 x 4GB) DDR4-3200 Memory  ($108.99 @ Newegg)
Total: $539.23
Generated by PCPartPicker 2018-01-12 02:30 EST-0500
https://linustechtips.com/topic/884933-help-upgrade-my-pc/#findComment-10929136
Here's an option with a R5 1600, 16GB DDR4 and a NVMe SSD.
CPU: AMD - Ryzen 5 1600 3.2GHz 6-Core Processor  ($198.89 @ OutletPC)
Memory: Corsair - Vengeance LPX 16GB (2 x 8GB) DDR4-3000 Memory  ($204.99 @ Amazon)
Storage: Samsung - 960 EVO 250GB M.2-2280 Solid State Drive  ($119.99 @ Samsung)
Total: $597.85
Generated by PCPartPicker 2018-01-12 02:37 EST-0500
PC Specs - AMD Ryzen 7 5800X3D MSI B550M Mortar - 32GB Corsair Vengeance RGB DDR4-3600 @ CL16 - ASRock RX7800XT 660p 1TBGB & Crucial P5 1TB Fractal Define Mini C CM V750v2 - Windows 11 Pro
https://linustechtips.com/topic/884933-help-upgrade-my-pc/#findComment-10929141
Total: $539.23
Do you think the 960 will be enough to handle DragonBall FighterZ and Monster Hunter World?
https://linustechtips.com/topic/884933-help-upgrade-my-pc/#findComment-10931772
No question.  You won't be running them on Ultra, but your GPU is already the strongest part of your system.  It's the rest that needed an upgrade.  Make sure you do a fresh install of Windows on the SSD. It's a pain, but you'll get huge benefits from it.
https://linustechtips.com/topic/884933-help-upgrade-my-pc/#findComment-10931783
