Best TN Panel
1 minute ago, cameronmcleod71 said:Do you do much gaming? I heard that g sync is a game changer for some games. I'm not sure if I'm correct though, maybe its not worth the money.
I do a ton of gaming, mostly esports type stuff
how much adaptive sync matters is on a case by case basis, depends on
If you notice screen tearing in X game
how much do you care about about screen tearing
If you can't get over 60fps in X game
adored's video is on free-sync but the same things apply. I wouldn't spend extra money for adaptive sync in any event, for 1080p 144hz TN displays it's nearly a $200 difference just to have the privilege of using G-sync.
PCPartPicker part list: https://ca.pcpartpicker.com/list/4MRnsJ
Price breakdown by merchant: https://ca.pcpartpicker.com/list/4MRnsJ/by_merchant/
Monitor: AOC - G2460PG 24.0" 1920x1080 144Hz Monitor ($489.99 @ Newegg Canada)
Monitor: Asus - MG248Q 24.0" 1920x1080 144Hz Monitor ($299.99 @ Newegg Canada)
Total: $789.98
Generated by PCPartPicker 2018-01-11 18:58 EST-0500
