Hello, I was planning to leave my pc on for 2 hours as I need to install GTA again (I installed a new graphics card and its messing GTA up) and it's been on for like 2 hours so will I damage it by leaving it on for too long? Keep in mind I have 3 fans on the case, I set it to turn off after 2 hours, I am VERY paranoid as it's really expensive and I've had it for a month.
https://linustechtips.com/topic/884389-pc-overheating/
No it will not overheat.
زندگی از چراغ
Intel Core i7 7800X 6C/12T (4.5GHz), Corsair H150i Pro RGB (360mm), Asus Prime X299-A, Corsair Vengeance LPX 32GB (4X4GB & 2X8GB 3000MHz DDR4), MSI GeForce GTX 1070 Gaming X 8G (2.113GHz core & 9.104GHz memory), 1 Samsung 970 Evo Plus 1TB NVMe M.2, 1 Samsung 850 Pro 256GB SSD, 1 Samsung 850 Evo 500GB SSD, 1 WD Red 1TB mechanical drive, Corsair RM750X 80+ Gold fully modular PSU, Corsair Obsidian 750D full tower case, Corsair Glaive RGB mouse, Corsair K70 RGB MK.2 (Cherry MX Red) keyboard, Asus VN247HA (1920x1080 60Hz 16:9), Audio Technica ATH-M20x headphones & Windows 10 Home 64 bit.
The time Linus replied to me on one of my threads:
https://linustechtips.com/topic/884389-pc-overheating/#findComment-10923468
no, assuming you have adequate active cooling and you are not running any intensive processes.
[FS][US] Corsair H115i 280mm AIO-AMD $60+shipping
System specs:
Asus Prime X370 Pro - Custom EKWB CPU/GPU 2x360 1x240 soft loop - Ryzen 1700X - Corsair Vengeance RGB 2x16GB - Plextor 512 NVMe + 2TB SU800 - EVGA GTX1080ti - LianLi PC11 Dynamic
https://linustechtips.com/topic/884389-pc-overheating/#findComment-10923479
if you have good cooling you should be fine
generally i'd always recommend a stress test on a new build to see if the ventilation is good under load, if not then that should be something you should've invested more research if its a serious issue
i can't see what you did (spacing, hardware, specs, etc.) based on a lack of a lot of information
https://linustechtips.com/topic/884389-pc-overheating/#findComment-10923511
What are your specs? You can run a synthetic load to see what your peak temps are. If your temps are fine under a heavy synthetic load, they'll be fine under just about any other situation.
https://linustechtips.com/topic/884389-pc-overheating/#findComment-10923588
