Byte Array help with Control Box Communication
So I currently have a Sit-stand desk which uses a control box to control the linear actuators to make the desk move up and down. The manufacturer gave me a key on how to communicate with the control box. Here it is:
1. What do I do with Byte 4 to make the desk go up? Look at key to the right for that Byte Description
2. Would I build a byte array with this?:
Byte 1: 0xD8
Byte 2: 0xD8
Byte 3: 0xff (This is the device ID)
Byte 4: What do I do for this to make the desk go up? Would I make bit 7, 6, 5, 4, 3, 2, and 0 a binary 0? Then would I keep the S+ a binary 1 because the key to the right says if S+ = 1 then it will move the desk up?
Byte 5: Needs to be the same as Byte 4
Once I'm finished with Byte 4, would I convert all those one's and zero's to hexadecimal?
Thanks!
Tech enthusiast and CS Student
Byte 4 bit 1 has to be set to true.
Yes. 1 means function is enabled, 0 means it is disabled.
That's not how numbers work...
Some code to make your life easier :
#define _DESK_BIT7_  0x80
#define _DESK_BIT6_  0x40
#define _DESK_BIT5_  0x20
#define _DESK_BIT4_  0x10
#define _DESK_BIT3_  0x08
#define _DESK_BIT2_  0x04
#define _DESK_BIT1_  0x02
#define _DESK_BIT0_  0x01
To enable function bit you have to bitwise or them :
int8_t Byte4 = _DESK_BIT1_ | _DESK_BIT2_ | _DESK_BIT5_;
If you only want to enable bit one :
int8_t Byte4 = _DESK_BIT1_;
